ᐅ How can I protect my Billy shelves from scratches caused by pets?
Created on: 17 Jan 2023 08:23
nova_goHello everyone,
I have a concern that has been on my mind for some time: I own several Billy bookshelves from Ikea, which I really appreciate for their flexibility and value for money. Unfortunately, my two cats have the habit of scratching the edges and surfaces of the shelves, causing unpleasant scratch marks. I would prefer not to replace the shelves, so I am looking for effective ways to protect the Billy shelves from further scratches caused by my pets.
It is important to me that the protective measures do not permanently affect the appearance of the shelves or require too much effort to install. I have already considered various protective films and covers but am unsure whether they will hold or if my cats might simply target other spots.
Does anyone have tips on how to effectively protect my Billy shelves from cat scratches, preferably with gentle methods that are easy to apply?
Thanks in advance for your advice!
PeoDaniel17 Jan 2023 09:37nova_go schrieb:
I’d rather not replace the shelves, so I’m looking for effective ways to protect the Billy shelves from further scratches caused by my pets.Hello nova_go,
Your issue is quite understandable and common in households with cats. Cats scratch furniture to sharpen their claws and mark their territory – this can never be completely prevented, but there are several ways to protect your Billy shelves specifically.
A proven method is to use transparent protective film or furniture protection film. These films are self-adhesive, relatively easy to apply, and protect the surface well from scratches. It is important to choose a film that isn’t too thick so the appearance of the shelves doesn’t change too much.
Alternatively, you can use special edge protectors. These are made of silicone or plastic and especially protect vulnerable corners and edges from scratches and impacts. Cats tend to scratch mostly on edges, so this is a good approach.
In addition, you should provide attractive scratching options for your cats – for example, scratching boards or posts placed near the shelves. Often cats limit their scratching on furniture if they have a suitable alternative.
One last tip: cats can be deterred from furniture with a bit of plant oil or special repellant sprays that are safe for pets. However, these should be used sparingly and always with consideration for your animals’ well-being.
I hope this helps! If needed, I can also recommend some sources for the protective films. 🙂
nova_go schrieb:
I have already thought about different protective films and covers but I’m not sure if they really hold up or if they might just cause my cats to scratch other spots instead.I find this consideration important. It is a simply overlooked fact that measures preventing direct scratching on a piece of furniture do not necessarily lead to an overall improvement in the situation. Cats have complex territorial and scratching behaviors. If the shelves are too well protected, the scratching pressure could easily shift to other, possibly even less desirable areas.
This means it makes sense to always follow a holistic approach that protects furniture while also providing cats with alternative scratching surfaces. Additionally, it is important to remain realistic: a certain residual risk of minor scratches is almost unavoidable with active cats.
At what height does the main scratching occur? Is it the edges, the fronts, or rather the surfaces? This could provide insight into how extensive and where exactly protective measures should be applied.
I would also recommend critically evaluating the use of films. Depending on the material, cats might tear or damage the films, which can lead to sticky residues. Researching the best-rated products—ideally with feedback from cat owners—is definitely worthwhile.
In short: a protection system that is consistent and takes the animal’s needs into account ensures success.
PeoDaniel18 Jan 2023 07:45faso31 schrieb:
If the shelves are too well protected, the scratching pressure could very well shift to other, possibly even more unwanted areas.That’s an important point I wanted to highlight as well. Finding the balance between protecting furniture and redirecting cats to alternative scratching surfaces is crucial.
novago schrieb:
I prefer not to replace the shelves, so I’m looking for effective ways to protect the Billy shelves from further scratches caused by my pets.Are there specific parts of the shelves that are particularly affected? Are the surfaces painted or covered with a veneer? That makes a big difference when choosing protective measures.
You could also consider attaching clear silicone corner protectors. They are flexible, absorb damage, and can be easily removed.
Additionally, many cat owners avoid tactile materials on furniture that are particularly appealing to scratch, such as rough surfaces that encourage scratching. Smooth surfaces are definitely an advantage.
If you like, I can later suggest some affordable products for films and edge protectors.
Timmyse3618 Jan 2023 21:17I completely understand how frustrating it is when your beloved furniture gets damaged by your own pets. Especially Billy shelves, which you really want to keep for a long time.
My advice: Try to playfully distract your cats from the shelves. Using catnip, toys, and regular engagement often works better than just passive protection.
I also once read that certain essential oil scents can deter cats – but be careful, many are toxic to cats. Only use recommendations from veterinarians or cat specialists in this case!
In the end, it’s important to be patient and combine different measures. The adhesive on protective films can also be a challenge if you want to use the furniture normally again later.
Keep at it, you can do this! 😉
