ᐅ How can I protect Malm furniture from mold?
Created on: 20 Sep 2024 18:47
sheldonk37
sheldonk37
20 Sep 2024 18:47
Hello everyone, I have a specific question regarding Malm-type furniture, especially those from IKEA, and how to effectively protect them against mold. My apartment sometimes has quite high humidity levels, which concerns me, particularly because I have already noticed early signs of mold on a Malm wardrobe. Are there proven methods or special products I can use to minimize the risk? I am especially interested in preventive strategies that are compatible with the materials of Malm furniture, as I am worried that aggressive treatments might damage the surface. I would appreciate concrete advice on how to control humidity, as well as how to protect the furniture itself, especially in the bedroom area. Thank you in advance!
nolan
20 Sep 2024 19:13
The most effective methods are regular ventilation and using a dehumidifier in the room. Furniture made of particleboard, such as the Malm series, should not be placed directly against exterior walls. Simply clean damp spots immediately, preferably with vinegar water, and keep the furniture surface dry.
Dilen
21 Sep 2024 08:29
To answer your question in detail: Malm furniture from IKEA is mostly made of particleboard sealed with a melamine coating. These surfaces are generally quite moisture-resistant as long as the coating remains intact, but they have limited tolerance for prolonged high humidity. Mold typically appears when moisture penetrates the wood material, for example through cracks, damaged corners, or localized water accumulation.
As a preventive measure, I recommend first measuring the relative humidity in the room. Values above 60-65% are critical. A hygrometer is a good tool for this. To prevent mold growth on the furniture, the best methods are:
1. Optimal ventilation: Cross-ventilate or air the room at least twice daily for 5-10 minutes each time.
2. Control humidity: An electric dehumidifier can help in cases of persistent high humidity.
3. Keep furniture away from direct contact with cold exterior walls to avoid condensation on the back side.
4. Regular cleaning with mild, non-aggressive agents, such as diluted vinegar solution or specialized anti-mold products for wood that do not damage the melamine surface.
Could you also describe how your bedroom is ventilated and how close the wardrobe is positioned to the wall? Room temperature also plays a role, as cold surfaces attract more condensation.
nolan schrieb:
Furniture like Malm made from particleboard should not be placed directly against exterior walls.
This is a very important point. If the back of the wardrobe becomes damp, this is often the first step toward mold growth. It’s best to leave a small air gap between the furniture and the wall.
GiRoyce
22 Sep 2024 14:03
I would like to add to the discussion on how to protect Malm furniture from mold and try to explain a few simple basic principles clearly.
First of all, the cause of mold is usually a combination of moisture and poor air circulation. Therefore, the most important step is to reduce indoor humidity. This can be achieved by regular ventilation, ideally in the morning and evening. Fans or air conditioners with dehumidifying functions are also very helpful.
Important for the furniture:
- Do not place Malm furniture directly against exterior walls or on cold floors. A small gap of at least 2-3 cm (1-1.2 inches) allows air circulation and prevents direct moisture absorption.
- Avoid placing clothing or other textiles, especially damp ones, directly into the wardrobe.
- Regularly check if the back panels, corners, or drawers are damp and gently clean these areas with a mold remover suitable for delicate surfaces.
If the humidity in your room frequently exceeds 60%, it is recommended to use a hygrometer to monitor the levels. This is especially important in bedrooms, where the air tends to be more humid after ventilation and sleeping, as we release a lot of moisture at night.
Another tip: Use dehumidifying sachets or silica gel packs in the drawers, which help to draw moisture out of the furniture.
Finally, I recommend not using aggressive cleaners that could damage the melamine surface of Malm furniture. A damp cloth with a bit of mild dish soap is often sufficient for cleaning.
If you are still unsure how to best measure or manage humidity in your room, feel free to ask. Sometimes a small change in ventilation habits is enough to prevent mold growth.
