ᐅ How can I protect IKEA PLATSA furniture from moisture damage?
Created on: 28 Nov 2017 19:23
Z
Zarfi32
Z
Zarfi32
28 Nov 2017 19:23
I recently purchased some IKEA PLATSA furniture and plan to place it in a room that can occasionally be a bit more humid (for example, due to drying laundry or slightly increased air moisture). Since PLATSA furniture is mostly made of coated particleboard, I’m concerned about possible moisture effects that could affect the surfaces or the stability over time.
My question is: What is the best way to protect IKEA PLATSA furniture from moisture exposure?
I am particularly interested in practical measures such as suitable sealants, surface treatments, placement guidelines (e.g., distance from the wall), or air circulation strategies. It would also be helpful to know if there are specific impregnations compatible with the materials that do not affect the appearance or function of the furniture.
I look forward to your experiences, recommendations, and tips!
Pome60
28 Nov 2017 20:47
Zarfi32 schrieb:
How can I best protect IKEA PLATSA furniture from moisture exposure?
Great question! The PLATSA system is really versatile, but moisture is its little enemy. Here are my tips:
- Definitely use a water-repellent wood stain or a thin layer of clear varnish on exposed surfaces, especially on edges and back panels. This helps make the surface more resistant!
- Important: Don’t place the furniture directly against an exterior wall if it’s cold and damp. Leaving a small gap of a few centimeters (inches) allows better air circulation and prevents mold growth.
- If the furniture is in a mostly humid room, make sure to ventilate regularly. Use a dehumidifier if needed to reduce moisture.
- One more tip: Protective mats or small plastic feet help protect the bottom edges from water stains.
I’d say this will give you good protection. Go for it, it will extend the life of your PLATSA furniture! 💪😊
bufukin
29 Nov 2017 06:05
Pome60 schrieb:
Do not place furniture directly against an exterior wall if it is cold and damp.
This advice is essential and should be expanded as follows:
- Particleboard panels, such as those used in PLATSA, have a high moisture absorption rate, which can cause swelling and deterioration.
- To prevent this, I recommend maintaining a minimum distance of 3–5 cm (1¼–2 inches) from the wall to allow adequate air circulation.
- Additionally, backs and cut edges should be treated with suitable moisture-resistant coatings. Polyurethane-based clear varnishes are recommended here, as they create a protective layer without altering the appearance.
Furthermore:
- Using breathable paints on the walls can reduce moisture absorption in the room.
- Employing a dehumidifier lowers relative humidity and protects all furniture.
These measures provide a practical basis for protecting furniture systems in damp conditions.
RON57
29 Nov 2017 21:38
Good evening,
I can understand the question well. PLATSA is made of coated particleboard, which can tolerate some moisture but is not designed for permanently damp environments. Therefore, proceed slowly and carefully:
- Seal raw cut edges: Especially cut edges (e.g., around drilled holes or edges that are not covered) absorb moisture more readily. I recommend treating all unprotected edges and also the back panels with wood preservative varnish or impregnating stain.
- Choose appropriate locations: Areas with high humidity, such as laundry rooms or bathrooms, should be avoided. If placement in such areas is unavoidable, ensure excellent ventilation or use a dehumidifier temporarily.
- Keep distance from walls: As mentioned several times, leaving at least a 3 cm (1¼ inch) gap is important to allow air circulation.
- Surface maintenance: Regular wiping with a well-wrung cloth helps prevent water stains.
- Additionally: There are special furniture wax products that create a protective surface. These can—if compatible—help prevent long-term moisture damage.
I hope this provides a good overview. If you have questions about specific products, just ask!
rekijan
1 Dec 2017 08:01
RON57 schrieb:
I hope this gives a good overview.
Definitely! And here are a few casual additions:
- A little trick that helped me: place a thin foam rubber mat under the furniture legs. It absorbs minor moisture traces and protects both the floor and the furniture feet.
- It’s also great to apply a breathable coating or a thin film to the back panels of the PLATSA units. This prevents moisture from seeping in from below while still allowing them to breathe.
- If it gets a bit too damp, some music and a good mood help 😉 – and of course, airing out the room more often!
- By the way, no need to panic: as long as you don’t keep the furniture permanently in a sauna or right next to a steam bath, they are fairly sturdy.
Good luck protecting your furniture! 🍀
