ᐅ How can I protect Ikea Hemnes furniture from moisture?
Created on: 20 Nov 2023 08:27
Sarfi
Sarfi
20 Nov 2023 08:27
I recently bought some IKEA Hemnes furniture, specifically dressers and shelves made of wood. Since I’m unfortunately not lucky enough to have a room that stays completely dry and there is sometimes some moisture in the air (close to the bathroom, heating not always on continuously), I’m concerned about how to best protect the furniture from moisture. The Hemnes series is made of solid pine wood and is oiled, but I want to avoid long-term damage like warping, swelling, or mold growth.
Do you have any recommendations on measures to protect Hemnes furniture well in such humid rooms? For example, I’m wondering if protective varnishes make sense, whether the furniture should be raised or placed on spacers, or if there are special care products available. I’m also interested to know if additional waterproofing treatments might seal the wood too much and potentially cause negative effects. Of course, I understand that wood, as a natural material, reacts to humidity in the air – but it should be protected as well as possible.
Thanks in advance for your experiences and valuable advice!
pikin
20 Nov 2023 12:03
Hello Sarfi,
It’s good that you brought up the issue of moisture protection for Hemnes furniture. These pieces are indeed oiled, which offers some protection, but it is not sufficient with high humidity and direct water exposure.
I recommend the following measures:
- Avoid placing furniture directly against cold exterior walls to prevent condensation.
- Maintain a gap from the floor, for example, using furniture glides or small supports, to prevent moisture from the floor affecting the furniture.
- Regularly ventilate the room to keep moderate humidity levels (below 60%).
- Apply additional treatments with wood protection oil or suitable hard wax oils (e.g., from product lines like Osmo or Livos), which penetrate the wood pores and increase moisture resistance.
- Do not use plastic-based paints or lacquers, as they can hinder the wood’s breathability.
Additionally, avoid dirt and standing water on the furniture. The mentioned oils can help repel moisture without fully sealing the surface.
These recommendations are proven in practice, especially for furniture made of soft pine wood like Hemnes. I hope this helps you.
GOLO42
21 Nov 2023 09:15
Hello Sarfi,
I would like to go into more technical detail because proper moisture management with solid wood furniture is more complex than many people expect.
Solid wood furniture, like the Hemnes series, is naturally hygroscopic, meaning it regulates moisture by absorbing and releasing water from the surrounding air. Of course, this carries the risk of the wood swelling or shrinking when humidity levels fluctuate significantly.
Balanced humidity and surface treatment are important:
- The factory-applied oil finish is open-pored, which prevents heavy water absorption but allows vapor permeability. It works best with stable indoor humidity levels between 40-60%.
- The desire for additional protection through waxes or hard oils is understandable, but these products must be compatible with the existing oil finish. Otherwise, uneven absorption, stains, or blistering can occur.
- Painted surfaces are often not ideal for furniture in damp environments because the wood can no longer regulate water vapor. This may cause cracking and warping.
My recommendation is to equip furniture, especially dressers, with feet or spacers to keep direct contact with the floor from occurring. This air circulation and gap allow moisture to escape more easily and reduce the risk of mold.
Also, please check whether the furniture is placed directly next to the bathtub or shower: splash protection (e.g., with waterproof materials) and avoiding direct water contact are essential.
You can also use technical dehumidifiers or at least a hygrometer to monitor indoor humidity, since excessive moisture is the main cause of damage.
Have you left the furniture untreated, or have you reapplied the factory oil finish? How much does the humidity fluctuate in your rooms? That information would help me provide more specific advice.
Sarfi
21 Nov 2023 11:42
GOLO42 schrieb:
Did you leave the furniture untreated or have you already reapplied oil over the factory-applied oil finish? How much does the indoor humidity fluctuate in your rooms? That would help to give you more precise advice.
Thank you for the detailed explanations! I assembled the furniture straight out of the packaging, so it only has the factory-applied oil finish. I haven’t reapplied oil yet.
I have actually used a hygrometer: the humidity usually varies between 55% and 70%, especially when the heating is off or set very low (for example, at night or during extended absences like vacations). The furniture is located in the hallway adjacent to the bathroom—not directly in a wet area, but also not in a perfectly dry space.
I hadn’t considered the gap from the floor before—I will look into getting furniture pads, preferably ones that allow air circulation.
Regarding re-oiling, I am unsure whether a hard oil or a thinly applied linseed oil is better. Are there clear recommendations for Hemnes pine wood? And how often should re-oiling ideally be done if one wants to improve moisture protection?
Paxton38
21 Nov 2023 14:07
Regarding the choice of oil:
For IKEA Hemnes furniture, I generally recommend a natural hardwax oil, as it creates a hard, water-resistant surface while remaining breathable. Osmo hardwax oils or similar product lines have proven to be suitable. These oils penetrate well, cure properly, and provide long-lasting protection.
Regular linseed oil penetrates deeply and nourishes the wood fibers but remains softer and makes the surface less resistant to mechanical wear and moisture.
The oil should be reapplied every 1–2 years, depending on wear. Before re-oiling, a light cleaning and, if necessary, sanding of the surface is advisable.
Maintaining a gap between the furniture and the floor is important because standing moisture is the main cause of damage. Additionally, regular ventilation and controlled indoor climate help.
If you like, I can also provide recommendations for specific care products.
Curtis
22 Nov 2023 07:54
I would like to add a critical perspective here:
pikin schrieb:
No painting with synthetic varnishes, as these can inhibit the wood’s breathability.
This argument needs to be viewed more nuanced. In particularly humid environments, water-based varnishes that are breathable can provide a sensible protective layer and significantly reduce moisture absorption, thereby preventing wood damage. Of course, this is a compromise between breathability and protection.
As a general rule: if the furniture piece is directly exposed to moisture or the humidity remains very high, a sealing varnish layer can indeed be helpful. Ultimately, it depends on the individual situation.
My recommendation is therefore to first maintain stable indoor humidity, promote air circulation, and, if in doubt, consider a sealant that is both diffusion-open and water-repellent.
For Hemnes furniture, it is also important not to mix surface treatments arbitrarily — if painting is done, all oils must be removed beforehand to avoid adhesion problems.
It would be interesting to know how often such furniture is treated with varnishes in humid rooms and what experiences other users have had here.
