ᐅ How can I protect IKEA BRIMNES furniture from scratches caused by children?
Created on: 30 Dec 2018 09:37
alfeo
alfeo
30 Dec 2018 09:37
Hello everyone, I would like to ask a question about protecting IKEA Brimnes furniture from scratches, especially when there are small children in the household. The BRIMNES range is known for its light finish and simple surface, which can unfortunately be quite sensitive with heavy use. My daughter is two years old and plays a lot in her room, causing small scratches and dents on the drawers and surfaces. I am looking for effective ways to protect this furniture from such damage without significantly altering its appearance or making major modifications. Are there any practical tips or proven products you would recommend? I am open to any suggestions that help keep the surface intact and prevent scratches in the long term. Thank you in advance!
Donar34
30 Dec 2018 10:03
As a precaution against scratches on BRIMNES furniture, I recommend the following proven methods: - Use transparent protective films or furniture films specifically designed for painted surfaces. These are nearly invisible and protect against mechanical damage. - Attach felt pads or plastic caps to corners and edges to reduce localized wear from bumps or knocks. - Clean regularly with mild cleaners without aggressive chemicals, as these can weaken the paint layer. - For heavy use, consider applying a matte wood or furniture sealant that can be lightly applied over the paint, provided this is recommended by the manufacturer. I advise against using heavy oils or waxes, as they can alter the surface texture. These measures increase protection without significantly affecting the original appearance.
GEKAU51
30 Dec 2018 12:27
Whether the effort involved with these protective films is really worthwhile is questionable. ‘[...] They are hardly visible and protect against mechanical impacts.’ You have to take that on trust, because films tend to peel off at the corners, especially when children fiddle with them. In addition, the texture changes, which is important for children. Why not simply accept that furniture in a child’s room will show wear? That is a sign of a lived-in home! Instead of wrapping furniture, it’s better to teach sensible rules. Of course, this is not always easy, but it is more sustainable than a cosmetic fix.
alfeo
30 Dec 2018 14:11
GEKAU51 schrieb:
‚[...] These are barely visible and protect against mechanical impacts.‘
That’s a valid point, especially with small children. The protection shouldn’t overly restrict my daughter’s play environment or feel unnatural. On the other hand, practicality is also important: replacing furniture frequently becomes expensive over time. I’m looking for a balance between protection and everyday usability. Do you have any experience with special touch-up pens or repair kits for minor scratches? Are there products that work quickly and neatly when damage does build up?
jelite
31 Dec 2018 08:46
To answer the question ‘How can I protect IKEA BRIMNES furniture from scratches caused by children?’ in more detail, here is a structured overview of practical solutions that have proven effective:
1. Preventive protection:
- Transparent, self-adhesive furniture film: easy to apply, protects against everyday scratches, low cost, and nearly invisible.
- Silicone or plastic corner and edge guards that secure play areas and protect the furniture.
2. Care and repair:
- Special touch-up pens or repair markers that match the BRIMNES color exactly can quickly cover small scratches. It is important that the pen is suitable for painted surfaces.
- Furniture polish that reduces minor scuffs and refreshes the protective layer.
3. Behavioral strategies:
- Teach children not to play with sharp objects near the furniture, which can be complemented by soft play areas such as rugs or cushions. In daily life, it helps to avoid using the furniture as a permanent playground and to set clear rules.
In general, harsh cleaning agents should be avoided, as they can damage the paint layer.
In summary, prevention with protective films combined with targeted repairs for small scratches is the most practical approach.
