ᐅ How can I prevent Billy shelves from creaking and squeaking?
Created on: 17 Mar 2021 10:37
Fokorhan
Fokorhan
17 Mar 2021 10:37
I have a somewhat specific question: My IKEA Billy shelves start to creak and squeak quite unpleasantly after some use, especially when I put weight on the shelves or even just slightly move them. The problem mainly affects the connection points between the side panels and the shelves, as well as the metal fittings.
I’m interested in knowing: How can I effectively prevent my Billy shelves from creaking and squeaking? What mechanical measures reliably help with this? Are there proven methods to permanently reduce wood-on-wood or metal-on-wood friction?
I look forward to well-founded tips, including advice on prevention before assembly or on repair for shelves that are already assembled. Thank you in advance!
FEKAU
17 Mar 2021 11:02
Fokorhan schrieb:
My Billy shelves from IKEA start to creak and squeak quite annoyingly after some use, especially when the shelves are loaded or even just slightly shifted.
This is a common issue with shelving made from particleboard or MDF combined with metal fittings. The main cause is often small tensions or minimal movements at the joint connections.
To effectively reduce this, I recommend:
1. Checking and tightening all screws and dowels, as loose connections create friction.
2. Applying wax or graphite powder on the contact points between wood and metal – this reduces friction.
3. Alternatively, using silicone-based furniture lubricant applied before reassembling the parts.
4. As a long-term solution, inserting thin felt or plastic strips at the contact surfaces can help avoid direct wood-to-metal contact.
These steps are straightforward and typically take less time than an average furniture assembly would require.
rekijan
17 Mar 2021 14:09
FEKAU schrieb:
Using wax or graphite powder on contact points between wood and metal reduces friction.
That’s right, and if you happen to be in the basement anyway, grab a piece of candle wax! Just rub a little over the squeaky spots, and the result almost feels like an upgrade.
Small rubber buffers or self-adhesive felt pads can also work wonders—without much effort. Sometimes it’s simply because the shelf “moves” a bit due to temperature changes and moisture; so you just need to do some maintenance now and then. Maybe also a good reason to check regularly. 🙂
What I personally would avoid are very liquid oils—they quickly create a nasty, greasy mess and attract dust.
LANICOLE
18 Mar 2021 08:15
Here is a brief guide on how to prevent and fix squeaking in Billy-style shelves:
1. Before assembly: Carefully inspect all parts, especially the drilled holes and edges. Sometimes the surface is rough, or small splinters increase friction.
2. After assembly: Gently retighten all screws, but avoid overtightening as this can damage the material.
3. Treat friction points:
- For metal-to-wood edges: use graphite powder or dry wax.
- For wood-to-wood contact: apply felt pads or self-adhesive foam strips.
4. Regular checks:
- Over time, connections loosen—check screws and dowels approximately every 6 months.
5. Avoid overloading, especially the shelves, as warping can cause tension and noise.
Common mistakes include using oils that attract dust or overtightening screws, which can damage the material. It is advisable to keep a small maintenance kit with wax sticks and felt tape for the shelves.
I hope this helps!
BeAndrea
18 Mar 2021 12:47
Fokorhan schrieb:
Which mechanical methods are reliably effective here? Are there proven solutions to permanently reduce wood-on-wood or metal-on-wood friction?
Some users also recommend using a combination of silicone spray and felt pads, where the silicone spray is applied carefully to dowels and screws just before assembly to keep friction low.
Additionally, it can be worthwhile to assemble the shelf on a level surface and make sure all joints are aligned parallel—crooked joints tend to cause squeaking noises.
If the shelf is attached to a wall, the wall fixings should also be checked because any movement there can make the entire structure unstable.
From my experience: this works very well even with older shelves when the right tools are used and the spots are treated precisely.
