Hello everyone, I own several IKEA Billy bookshelves in my apartment, and unfortunately, I have the problem that my pets – specifically two playful cats – keep damaging these shelves. It’s not just scratches on the edges, but also chewed backs and gnawed feet.
I would really like to know: What can I do to protect my Billy bookshelves from such damage caused by pets, without significantly affecting the style or functionality of the shelves?
I am especially looking for practical and long-term effective solutions that are also compatible with the relatively inexpensive materials used in the Billy bookshelves.
Looking forward to your tips and experiences!
Hello Tilu56, your concern is very understandable, and I’m quite familiar with this issue! Unfortunately, Billy shelves are fairly delicate because they are made of particleboard with a veneer surface, which can be easily damaged by scratches, moisture, or mechanical stress.
Effective protection is best achieved through a combination of measures. First, you should consider where the damage occurs most frequently – is it the backs, edges, or feet? Targeted protective steps could include:
1. Covering edges with transparent hard plastic edge protectors: These small strips are available ready-made and can be easily attached with double-sided tape. This significantly reduces wear and claw marks on the visible sides.
2. Reinforcing the backs with a thin plexiglass sheet fixed in place with suitable fittings. This prevents cats from chewing on the back panels.
3. Especially the feet: Pets often nibble on the lower parts of furniture. Here, a small metal plate protector or durable furniture leg covers (also called socks or caps) that slip over the feet can help.
4. Not to be underestimated: Providing a few cat toys and scratching posts nearby can reduce the appeal of the shelving unit to your cats.
I’m curious: What are your cats like – are they aggressive or more playful? That can help tailor the protective measures.
kaubi schrieb:
Not to be underestimated: A few cat toys and scratching posts nearby can reduce the attractiveness of the shelf for your cats.kaubi is right—if your cats burn off energy elsewhere, the shelf stays mostly untouched 🙂
Another thing you could try is sprays with natural scents (e.g., citrus or eucalyptus) that cats often dislike. You can spray these on the problem areas. But be careful: don’t use them too often, and always ventilate well, or you might ruin your own enjoyment of the shelf 😉
Oh, and maybe some stylish fabric covers or lightweight foam panels that you attach to the spots that get scratched frequently. This helps preserve the look somewhat and makes those “target areas” less appealing to your furry friends.
geralu schrieb:
Cats don’t like double-sided tape. That’s true, but sometimes cats want to play with tape and end up pulling it off – especially with playful animals, you can expect that this won’t provide lasting protection.
I’m also wondering whether applying a UV-cured clear coat could strengthen the surface of the Billy shelves. There are special protective wood finishes that are relatively scratch-resistant – has anyone tried this? Could this possibly preserve the natural appearance while significantly increasing durability?
Additionally, what about preventive measures? For example, you could use motion sensors that trigger an unpleasant sound for the cats when they approach – maybe a bit extreme, but in many households, technical aids have become quite popular.
It would still be very helpful to know which types of damage occur most frequently and exactly where cats prefer to mark or scratch.
