ᐅ How can I perfectly customize Billy shelves for niches?
Created on: 29 Jun 2020 08:17
pauken51
pauken51
29 Jun 2020 08:17
I’m looking for ways to perfectly fit IKEA Billy bookcases into base cabinet niches or other unusual niche dimensions. The challenge is that these niches often don’t match the standard width or height of the bookcases, and I want to achieve a precise fit with minimal carpentry work or expensive custom solutions. What components, additional products, or methods have you tried to install Billy bookcases securely in niches without them wobbling or looking out of place? Are there any tips for adjusting the back panels, sides, or shelves? I look forward to hearing your experiences and recommendations, including materials or tools you would use.
PIERCE
29 Jun 2020 10:22
Hello, I would recommend either shortening the shelves individually with separate insert shelves or stabilizing them with additional wooden strips. Use furniture glides or small wedges to compensate for unevenness. This often results in a solid, precisely fitting solution.
klo40
29 Jun 2020 12:07
Hello pauken51,
First, you should carefully measure the exact dimensions of the niche, including the depth and any possible angles.
1. Adjust side panels: You can cut the side panels to size or customize them by attaching thin MDF boards.
2. Shorten the back panel: The back panel is usually clipped or nailed in place. It can be easily trimmed to size with a fine saw.
3. Shelves: These can be cut down or you can use additional rows of holes for more flexible positioning.
Tip: Use fine wooden dowels and wood glue for stability. This will prevent the shelf from tipping forward or wobbling.
If you don’t have the necessary tools, simple hand saws and a cordless drill are sufficient. No special machines are required.
I hope this gives you a good starting point for your planning!
elgla
29 Jun 2020 13:43
I think your question is very important because many people face similar challenges. I also felt nervous about imprecise fitting pieces and worried about costly mistakes.
PIERCE schrieb:
Shims or small wedges to level out unevenness.
That’s a great tip that gave me confidence. I encourage you to proceed slowly when making adjustments, measure several times, and work narrower rather than wider. You really learn best by trial and error.
What kind of recess do you have? More short and wide, or narrow and tall? This can sometimes make it easier to find the right balance between trimming and stabilizing.
pauken51
30 Jun 2020 07:54
Thank you all for the initial tips!
My niche measures about 80 cm (31.5 inches) wide, 38 cm (15 inches) deep, and just under 190 cm (75 inches) high. The shelf itself is slightly too wide (Billy is 80 cm (31.5 inches) wide, but with my non-standard height, a few millimeters less width would be almost the same since the walls are slightly uneven). I think I’ll start by using thin wooden strips on the sides to even out small gaps. The back panel and shelves still seem like a challenge because I don’t want to compromise stability and I don’t have any specialized machines.
elgla schrieb:
Man lernt wirklich am besten durch ausprobieren.
Very true, but I want at least a theoretical basis so I’m not going in completely blind. Are there any recommendations for materials suitable for widening strips or filler strips for Billy (e.g., MDF, pine)? Experience with surface treatments would also be helpful, so the shelf doesn’t look old or worn.
klo40
30 Jun 2020 11:33
For construction, MDF is often the best choice because it is easy to saw, glue, and sand. For the surface, you can use white acrylic or wood paint, which also works well for IKEA finishes.
You can attach the moldings with wood glue or small screws. Then, lightly sand them (e.g., 120 grit) to round off the edges before applying the paint.
Tip: Using pine moldings gives a more rustic look, which works well if you want to maintain that style. For a clean IKEA-style appearance, MDF and paint are the better option.
Also: Make sure to double-check all measurements and fit the moldings as precisely as possible to any niche dimensions to avoid needing adjustments afterward.
