ᐅ How can I best use IKEA Metod cabinets in rooms with sloped ceilings?
Created on: 11 Jun 2020 19:23
Tegarrett
Tegarrett
11 Jun 2020 19:23
I am currently facing the challenge of installing IKEA Metod cabinets in my newly converted attic room. The main issue is the steep roof slope, which makes it difficult to arrange the cabinets in a continuous straight line. Therefore, I am looking for good advice on how to best adapt the Metod series to such a sloped ceiling in order to make optimal use of the available space.
Specifically, I am interested in:
- What options are there to partially customize or cut the cabinets?
- Does anyone know clever combinations of cabinet modules that work well with sloped walls?
- How can storage space be maximized despite the slope, especially in the lower areas?
I want to avoid unnecessary tinkering or ordering expensive custom-made pieces, but of course the solution must also be stable. Maybe someone has experience with additional parts or IKEA’s internal planning tools that are particularly suitable for sloped ceilings?
Thank you very much for your tips and suggestions!
PEDRO40
11 Jun 2020 20:11
Hello Tegarrett,
I can really relate to your situation, as I faced the same problem a few months ago.
Tegarrett schrieb:
I’m therefore looking for good tips on how to best adapt the Metod series to a sloping ceiling like this, to make optimal use of the available space.
This is indeed a challenge, especially since the dimensions of Metod units are quite fixed. What helped me was first measuring the height at several points, as the slope often changes unevenly.
Then I cut the cabinets flush underneath the slope, carefully sanding the cabinet doors with sandpaper to make them visually fit well. For the upper areas, I used open shelves, which are less dependent on precise measurements and also look visually lighter.
It’s also important to ensure stability: make sure to screw the cabinets securely to the wall, otherwise everything can quickly become crooked.
In the lower sections, I liked using drawer inserts, as they make better use of the depth of the space. Hope this helps you a bit!
Lilygla
12 Jun 2020 08:47
Hello Tegarrett,
I find your question very interesting and would like to address it in more detail.
Tegarrett schrieb:
What options are there to partially customize or modify the cabinets?
Basically, IKEA Metod cabinets are modular standard units, but for sloping ceilings you need to plan individually. In my experience, there are two practical approaches:
- Custom sizing by cutting: You can relatively easily trim the Metod plinths and cabinet sides with a jigsaw. Be sure to maintain stability by adding reinforcing brackets and treating the cut surfaces to prevent moisture penetration.
- Internal adjustments: You can flexibly configure the interior elements, for example by using a narrower base cabinet and a shallower cabinet with open shelving above it, so the slope above can be utilized.
A good idea is to install full-extension drawers in the shallower sections. You can also store deep items well this way. Also, make the most of available surfaces behind doors, for example with hooks or narrow shelf inserts.
Finally, I recommend creating a precise floor plan and possibly using the Metod kitchen planner software – this lets you try different combinations, even if you are not planning a kitchen.
I would also be interested to know the maximum cabinet height you have and how steep the ceiling slope is. This would help to think through the options more specifically.
pinpa
12 Jun 2020 11:36
Hey Tegarrett,
nice question, it immediately reminds me of my own adventures in the sloped-wall zone 😉
Here’s what worked well for me:
- I started with open shelves at the top, which can be easily adapted to fit the slope – basically like a stylish bookshelf that grows with the space.
- Below that, I used regular Metod cabinets, some of which I adjusted with leveling feet to compensate for the slightly uneven floor.
- The trick was often not to fully shorten the doors, but just to round off the bottom edges slightly. This saves a lot of work and is barely noticeable afterward.
And don’t worry, this kind of adjustment is actually really fun in the end! It feels like bending the IKEA system instead of breaking it 😄.
For combining elements, I recommend replacing cabinet doors with drawer fronts – that creates straight lines, especially when the wall is slanted.
Lilygla schrieb:
I’m also curious about your maximum cabinet height and how steep the roof slope is?
Yes, I think that’s also really important. If you give more details there, we can probably come up with a suitable idea for you.
Are you looking more for lots of storage space, or more open shelving for decoration and such?
