ᐅ How can I level IKEA PLATSA furniture on uneven floors?
Created on: 18 Sep 2017 20:17
Gregg65
Gregg65
18 Sep 2017 20:17
Hello everyone, I recently purchased several IKEA Platsa furniture pieces and am now facing the problem that my floor is uneven. Because of this, the shelving wobbles slightly, which not only looks untidy but also carries the risk that the furniture could tip over. I am therefore interested in which methods or tools can be used to stabilize and securely level IKEA Platsa furniture on uneven floors. Are there specific adjustable feet, leveling materials, or other practical solutions that have proven effective in practice? It would also be helpful to know how to proceed if the floor has varying degrees of slope or minor irregularities. Thanks in advance for your tips!
Gino38
18 Sep 2017 21:04
A proven method to level IKEA PLATSA furniture on uneven floors is to use adjustable furniture feet. Although IKEA does not offer specific feet for PLATSA, there are universal furniture glides or feet available for separate purchase. These can be individually adjusted to the floor irregularities and noticeably stabilize the furniture piece.
Alternatively, small wooden or plastic wedges can be placed under the furniture legs. It is important that the contact surface is large enough to distribute the pressure evenly and avoid damaging the furniture. Non-slip rubber pads can also help stabilize the height adjustment while preventing the furniture from sliding on smooth floors.
For those skilled in DIY, custom adjustable wooden supports can be built underneath, but careful attention must be paid to precise fitting.
O
ONRONA
19 Sep 2017 09:32
Gino38 schrieb:
Alternatively, small wooden or plastic wedges can be used, placed under the furniture legs.
This idea is generally practical; however, it should be noted that simple wedges alone cannot fully prevent tipping on significantly uneven floors. Stability largely depends on how well the weight is distributed across the furniture and whether the connection between individual modules is sufficiently sturdy.
Therefore, my question to the community is: Has anyone had experience with how the combination of wedges and possibly additional anchors or wall fasteners affects PLATSA furniture on uneven flooring? I believe that wall fastening is an almost essential measure for taller units to ensure safety, regardless of the floor conditions.
Joshbe
19 Sep 2017 10:17
I would like to add to ONRONA’s point:
- IKEA PLATSA furniture is modular and usually connected with screw systems. This means the overall integrated stability is limited, especially with tall or narrow units.
- For uneven floors, I recommend using adjustable feet or shims along with additional wall anchoring to eliminate the risk of tipping.
- IKEA often provides specific wall fasteners for individual furniture pieces — with PLATSA, it is essential to install these.
- For leveling the floor, self-adhesive felt pads can also be used as a small spacer to compensate for minor unevenness.
In my view, the combination of adjustable feet or shims and wall anchoring is the most efficient and safest approach.
ritotar
19 Sep 2017 11:42
If the floor is uneven, you obviously can’t just turn it into a fan of the new PLATSA, but a few tricks can help manage this issue! 😄
I simply attached a few adjustable furniture legs under the PLATSA units – this way, you can almost magically level the entire setup. If someone doesn’t want to buy extra parts, thick felt pads or self-cut wooden shims placed under the feet often do the trick as well.
I think this not only makes the structure more stable but also protects the floor from being compressed by the weight of the furniture. And as others have already mentioned, don’t forget the wall anchoring – it provides the final support, especially for larger constructions.
libar49
19 Sep 2017 12:26
ritotar schrieb:
I simply attached a few adjustable furniture legs under the PLATSA modules – this way, you can almost magically get the whole setup perfectly level.
Interesting, but one might wonder if that doesn’t compromise the furniture’s charm and design. IKEA designs these pieces with clean lines and a modular concept, so added extensions tend to stand out visually. Why not just level the floor or choose different furniture? In my opinion, this only hides the problem instead of fixing it.
Furthermore, the mentioned wall mounting is often more of a last resort. Anyone relying on the furniture’s stability without tipping over might want to consider a different approach altogether. My theory: the furniture simply isn’t designed for significantly uneven floors.
