Hello everyone, I am currently looking into how I can custom paint my IKEA Metod kitchen cabinets to give them a more personalized appearance. The surface of the doors is often coated and quite smooth, so I’m wondering: what preparation is necessary to achieve a durable and even paint finish? Do I need to sand the doors, use a primer, or is one type of paint better than others? I’m also interested in which techniques are recommended – brush, roller, or spray application? And regarding the paint itself – should I use acrylic or alkyd paint, or is there a better alternative specifically for Metod cabinets? I look forward to your experiences and tips, as it’s a difficult decision for me and I want to avoid as many mistakes as possible.
AMELIE schrieb:
Before you paint, I recommend pre-treating the edges with gently rounded sanding motions. Well observed, this greatly improves durability. Edges are stress points and often create weak spots during painting.
Another tip: After the final sanding and before the first layer of paint, wipe the surface again with a cloth dampened with isopropanol. This removes small traces of grease that can affect paint adhesion.
Regarding technique: If a spray gun is not an option, use high-quality paint rollers designed for fine finishes. I would only use brushes in small corners or for touch-ups.
Thank you for the detailed tips and your step-by-step explanation, PAR63, and thanks to everyone else for the helpful additions! In summary, I have now learned that the process looks like this:
- Thoroughly clean and degrease the doors
- Sand with fine sandpaper (180-220 grit) before priming
- Apply plastic adhesion primer and lightly sand again after drying (320 grit or finer)
- Paint with acrylic paint (or 2-component paint for professionals), preferably using a spray gun or spray can
- Don’t forget to sand between paint layers to achieve a smooth surface
- Gently round off edges and ensure a dust-free environment
- After sanding, wipe down with isopropanol
I will follow your instructions and hope the result meets my expectations. Once I get started, I’ll report back with my experience!
That sounds like a very well-thought-out plan. It’s clear you’ve put a lot of thought into it, and it will definitely turn out well. When choosing colors, I would also consider whether the shade is UV-resistant, especially if the kitchen gets a lot of natural light. This will prevent the color from fading. Additionally, patience when drying pays off—it's better to allow extra time rather than moving on too soon and damaging the paint finish.
I have been following along and can only say: very well summarized! I wish you the best of luck with the painting, and don’t worry— even if the result isn’t perfect, you can always do some touch-ups later. One more question for you: Are you planning to paint only the doors, or also the cabinet carcass parts? The latter are often made from different materials and require a slightly different approach.
BeAndrea schrieb:
One more question for you: Are you planning to paint only the doors or also the carcass components? For now, I plan to paint only the doors and possibly the panels, since those are the most visible. The carcasses are made of melamine-coated particleboard anyway, and I’m not sure if it’s worth it. If painting the doors goes well, I’ll consider working on the visible surfaces of the carcasses too, probably paying even more attention to the primer.
