ᐅ Why does the color of BILLY fade over time?
Created on: 27 May 2021 18:03
Tikikla
Why does the color of my Billy bookshelf fade over time? I have a few shelves that have noticeably lost color intensity after about two years of use, especially when exposed to direct sunlight. Are there any material or manufacturing factors that might explain this fading? I’m particularly interested in whether it’s related to the paint, UV exposure, or possibly the particleboard used. Or could it be care instructions that I might have overlooked? I use the shelf in a bright room and wonder how durable the color quality of the BILLY really is.
PLOMA
28 May 2021 07:45
RON57 schrieb:
BILLY shelves are made from inexpensive materials that do not provide the same level of UV protection as more expensive types of wood or specially treated surfaces.
That is exactly the issue.
Additionally, I wanted to add that excessive moisture in the room or cleaning with alcohol-based products can also damage the surface and cause the pigments to fade more quickly. Some cleaning agents can break microscopic bonds in the sealant, which accelerates the fading of the color.
It would be interesting to know if anyone has experience with post-treatments such as clear varnish or UV-protective sprays on BILLY.
NIKA61
28 May 2021 08:33
I can confirm that direct sunlight is problematic for BILLY. My shelf stood next to the window, and the color changed noticeably after about 3 years.
Since I started using a thin curtain, the fading has slowed down significantly.
Bagupo
28 May 2021 09:01
I would mainly attribute the cause to UV light.
Once the paint has faded, it is hardly possible to repair it on BILLY. Therefore, it is better to take precautions as already mentioned.
Tikikla
28 May 2021 11:26
kulau schrieb:
The best location would be one that provides enough light but avoids direct sunlight to minimize this issue.
Thanks to everyone so far! I’m now quite sure that sunlight is indeed the main cause. I will move the shelf a bit away from the window and install a UV-protective curtain.
One last question: Does anyone have suggestions on how I might refresh the faded areas? Painting or other treatments aren’t exactly straightforward with a BILLY, right? Alternatively, I’m also looking for tips on protecting a new unit.
kulau
28 May 2021 12:05
Tikikla schrieb:
Does anyone have tips on how I might refresh the fading areas a bit?
This is actually quite difficult with BILLY. The surface is usually a thin melamine foil, which does not sand or repaint well. Applying a clear coat can cause visible spots and an uneven appearance due to inconsistent adhesion.
What might work are special repair kits for furniture surfaces, such as color-matched waxes or markers, but these are more of a minor cosmetic fix and not very durable.
For a new shelf, you should consider the following:
1. Place it out of direct sunlight
2. Use windows with UV protection film or curtains
3. Use gentle cleaning methods without harsh cleaners
This will help preserve the color intensity for as long as possible. If you still want to repaint, it’s best to have it done by a carpenter or a skilled DIY friend, as the surface can easily get damaged otherwise.
If you like, I can also provide more detailed advice on care products.
