ᐅ How can I increase the load-bearing capacity of IKEA BRIMNES furniture?
Created on: 12 Mar 2020 14:37
Lisnon41Hello everyone, I am currently looking into how to increase the load-bearing capacity of IKEA Brimnes furniture. These pieces are known to be on the more affordable side and are mainly made from particleboard and simple joints. Since I plan to use the cabinets in an area that will experience heavier use—such as for storing heavier items or in a small workshop—I would like to know how to improve their stability and load capacity without having to switch to completely different furniture.
I am considering solutions like reinforcing the joints, adding additional cross braces, or using better screws or even metal brackets. I have also thought about material reinforcements, like adding extra panels or wooden strips inside. What I am most interested in is your experience with such reinforcements on BRIMNES furniture, or if you have other practical tips to increase durability under continuous load without drastically changing the design or spending a lot of money.
Perhaps some of you have already made modifications that help make the furniture stronger? I look forward to your advice, even though this might not be the most common topic!
Basically, I recommend systematically improving the load-bearing capacity of IKEA BRIMNES furniture by specifically addressing its weak points:
- Reinforcing corner joints: Using metal brackets or wooden braces at critical connection points increases rigidity.
- Adding material: Installing additional wooden panels or MDF strips inside to strengthen the back panels and reduce tipping tendencies.
- Optimizing screw positions: Replacing the original screws with longer or higher-quality ones can enhance holding strength.
- Shelves and bases: Adding extra shelves or reinforcing existing ones prevents sagging under load.
It is important to fit reinforcements in a way that does not affect the original function—for example, drawers should still operate smoothly, and no edges should be altered in a way that causes issues. However, the original load recommendations from IKEA should not be significantly exceeded to avoid material fatigue.
jokau schrieb:
Metal brackets on the corners help a lot.That makes sense. So far, I assumed the connections on BRIMNES were designed for simplicity, but using metal brackets on the corners is an idea I definitely want to try.
toril schrieb:
Installing additional wooden panels or MDF strips inside to reinforce the back panelsWhat is the best way to attach those? Wood screws or suitable mounting adhesive? Are there any experiences regarding which is more stable in the long term and less invasive? I want to keep the appearance as untouched as possible, so no visible screws on the outside.
Also: Has anyone had experience if the basic structure of BRIMNES even allows this? Sometimes I get the impression the individual panels are quite thin and can be easily damaged with too many screws.
Thanks in advance for your insights!
I can well understand how frustrating it is to have furniture that should really be able to withstand a bit more than originally intended. I myself have some BRIMNES cabinets and have tried to reinforce them – it works surprisingly well if you focus on the right spots.
Regarding the topic of “attaching panels inside”: I screwed MDF panels from the inside onto the back panel using small screws – the holes are barely visible and the stability increases significantly. I find it important that the screws are not too large, otherwise the material can split. I personally use less glue because it often doesn’t provide as strong a mechanical connection.
Also, if possible, I would place the furniture on a hard, level surface and pay attention to additional glides under the feet – this also helps distribute the load better and prevents tilting.
I’m curious to see how your reinforcements will turn out in the end!
