ᐅ How can I flexibly adjust IKEA Metod cabinets during renovations?
Created on: 16 Feb 2020 08:17
parludov52
parludov52
16 Feb 2020 08:17
I am currently facing the challenge of wanting to adapt several IKEA Metod kitchen cabinets flexibly in a renovation project. Specifically, I am interested in how to modify or alter the individual components – especially the cabinet carcasses – so that they can be easily adjusted later to fit different room layouts.
In particular, I am curious about the following points:
- What are the best ways to modularly expand or reduce Metod cabinets?
- What options are available to adapt cabinets to changed room dimensions (for example, sloped ceilings or uneven walls)?
- Are there any proven tricks to later adjust the cabinets’ height or width flexibly?
- What about stabilizing measures when altering the standard construction?
I would really appreciate hearing about your experiences here – including practical tips that might not be obvious at first. Thanks in advance!
Tevin
16 Feb 2020 09:46
Hello parludov52,
you’ve asked a very good and also quite complex question. IKEA Metod cabinets are actually designed for modular use, but modifying and adapting them beyond the intended dimensions is naturally a different challenge.
Regarding your points:
- Modular expansion/reduction: The cabinet boxes are standardized (typically 40/60/80 cm (16/24/32 inches) wide), with no intermediate sizes available. To stay flexible, you can expand the system by placing cabinets side by side or arranging them at different heights. For variable floor plans, it can be helpful to leave open side panels or work with cover panels.
- Adjustment to sloping ceilings or uneven walls: Here, cabinets with adjustable legs work well, combined with custom-cut panels and claddings. Especially sloping ceilings often require individual cuts on the top or adjustments to the sides.
- Subsequent changes: Adjustable legs are great for height changes, but changing the width is only possible by replacing the entire cabinet box. If you need to fill small gaps, IKEA offers some cover panels in various widths.
- Stability with altered configurations: If you disassemble or reassemble cabinets, it’s crucial to ensure the correct installation of the connectors. For tall cabinets in particular, wall mounting is recommended to avoid tipping hazards.
Maybe one more tip: if you want more flexibility, you could also consider combining individual pull-outs or shelves with flexible insert systems. This way, you can respond quite individually to changing needs.
I hope this helps you get started!
kla69
17 Feb 2020 14:53
Hello parludov52,
I would like to build on that and take a closer look at your plan, because the flexible remodeling of Metod cabinets is usually quite a technical task that requires a lot of precision.
Regarding your question on how to adapt Metod cabinets flexibly during remodels, I would first measure the space conditions very carefully, as these greatly limit the possible approaches. Here are my detailed thoughts on the individual points:
- Modular expansion or reduction: The cabinets come in fixed module sizes, which means resizing is only partially possible, except by using custom-cut panels as a sort of “room divider.” If you want to adjust the width, you usually need to replace the carcass or modify it using internal partitions. For example, an 80 cm (31.5 inch) carcass can be divided inside with partitions to create different sections — but this is a rather fiddly process and requires good tools.
- Adjustments for sloped ceilings or uneven walls, in my view, require precisely made panels and possibly additional trim. Special attention should be paid to the top cover panel, as cuts are needed there to match the cabinet height exactly to the slope.
- Looking at the height of a Metod cabinet, the adjustable feet help only to a limited extent since they compensate just about 10–20 mm (0.4–0.8 inch). For larger height modifications, you need tools to modify the feet or the plinth. However, caution is advised here because load-bearing capacity and stability can be compromised.
- Stabilization: Especially if you disassemble and recombine the carcasses, I always recommend reusing the original connections as closely as possible. If there are deviations, you should install reinforcing steel brackets or additional hooks. Some users report that clamps or special brackets help to protect the carcass against twisting.
Finally, an important question for you: Are you planning the cabinets as freestanding units only, or should they also be flexibly combined with overhead and wall mounting? The requirements for fastening and stability differ significantly between these.
I hope this gives you some clear guidelines. If you like, feel free to share more details about your remodeling project.
retau
18 Feb 2020 12:37
That’s a great point! Especially if you want to stay flexible during renovations, it’s worth using wall-mounted modules – this saves a lot of space and makes later adjustments much easier.
In my last kitchen renovation, I simply went with a combination of tall cabinets and wall-mounted cabinets that can be adjusted flexibly. I even bought special connectors to be able to detach and rearrange the cabinets when needed.
My advice for anyone wanting to stay flexible:
- Use adjustable feet for base cabinets
- Work with connectors that allow for disassembly
- Plan a modular basic structure from the start that can be quickly assembled or taken apart later
Then renovating really becomes fun, and you can easily change the order or combination at short notice.
Don’t get discouraged, it works great! 🙂
