ᐅ How can I equip Ikea PLATSA furniture with LED lighting?
Created on: 25 Dec 2019 17:32
Tytusron
Tytusron
25 Dec 2019 17:32
I am planning to equip my Ikea Platsa furniture with integrated LED lighting and am looking for practical and aesthetically pleasing solutions. Specifically, I am interested in the best ways to integrate LEDs into shelves or cabinet units without visible cables interfering or compromising the modular design. It would also be helpful to know which types of LEDs are recommended (for example, strips, modules, or spotlights), and how to handle the power supply ideally—especially regarding safety and ease of use.
Does anyone have experience installing LED lighting in PLATSA systems and can provide tips on materials, tools, and procedures? Advice on the optimal placement of the lights (inside, outside, back panel, underside) and possible diffusers would also be great. Thank you in advance for your suggestions!
RIDAN
25 Dec 2019 18:07
Hi, I would recommend LED strips that you can easily stick onto a back panel. For wiring, it’s best to route a flat cable towards the back so it remains hidden. If there are limited power outlets, a transformer can be installed inside an adjacent unit.
Le_kin
25 Dec 2019 19:14
To equip the PLATSA furniture with LED lighting, it makes sense to approach the project step by step. First, I would recommend defining the exact purpose: Should the lighting be primarily functional (e.g., to better see the contents on the shelf) or more decorative?
Regarding installation:
- PLATSA back panels are usually made of thin particleboard, which makes it easy to mount LED strips with adhesive backing.
- A single-sided 12V LED strip is ideal to ensure safety (low voltage).
- Wiring can be routed inside the hollow spaces along the side panels using cable ducts or cable clips to keep things tidy.
- Make sure that the power supply (transformer) is appropriately rated depending on the length and power consumption of the LED strips.
- For diffuse lighting, a frosted glass diffuser or a milky cover can be mounted in front of the LED strips to avoid visible point lighting.
As an alternative, small LED spotlights can provide indirect lighting, but these are more difficult to install and usually require drilled holes in the wood.
If you like, I’m happy to ask more about your specific setup and room size to provide more detailed advice.
LAYNE
26 Dec 2019 08:52
Hello Tytusron,
I think LED lighting integrated into furniture is a real eye-catcher and very practical when installed cleverly! 😎 For PLATSA, I would also recommend LED strips because they are flexible and can be fitted almost anywhere. What I really like is a narrow, milky plastic channel (as a diffuser) that makes the light much more pleasant – no harsh glare, just a nice even glow.
Pro tip: Run the cables discreetly along the inside of the furniture using small adhesive mounts or cable ties. And if you want to dim the LEDs, use a dimmable power supply right away – then you can create the right atmosphere anytime with a remote control.
If you want, please share whether you’re looking for a practical solution or if the light design itself is more important to you – that way, people can help you even better! 😉
dunitan
26 Dec 2019 12:36
Hello Tytusron,
Some time ago, I installed LED lights in PLATSA myself and would be happy to share my experiences. It was important to me that the solution remains reversible in case I want to make changes later.
My approach:
- I used 12V LED strips with a self-adhesive backing, which can be easily stuck to the back panel.
- I routed the wiring through the existing openings in the wood panels and secured the cables inside with cable channels. This way, no cables are visible.
- A small 12V power supply is hidden inside a nearby enclosed cabinet to keep the cables out of sight.
- To achieve even light distribution, I placed frosted acrylic panels in front of the LEDs, as the LED strips otherwise shine spotty in some areas.
Important: Make sure to check the power supply’s load capacity to avoid overloading. Most LED strips also come with compatible USB or 12V power supplies.
If you want more technical tips, just let me know!
minbi
26 Dec 2019 14:23
I find the discussion interesting, but it is important to take a closer look at how the structural integrity of the PLATSA components is affected by the installation of LED elements. Many users underestimate how the additional wiring and mounting can alter the piece of furniture.
dunitan schrieb:
For me, it was important that the solution remains reversible in case I want to make changes in the future.
That is a very important point. Often, silicone or strong adhesives are used that can cause problems later on. Additionally, the power supply should ideally not be routed out of the furniture through long extension cables, but be integrated directly within the furniture to minimize risks.
Choosing a 12V system is definitely safer compared to using 230V LED spots inside the furniture. This should definitely be emphasized.
