ᐅ How can I equip IKEA Metod cabinets with interior lighting?
Created on: 27 Jul 2021 18:23
Haroldfi
Haroldfi
27 Jul 2021 18:23
Hello everyone, I’m considering how to best equip IKEA Metod kitchen cabinets with subtle and practical interior lighting. It’s important to me not just to have a simple light source, but something that integrates well inside the cabinet, is as energy-efficient as possible, and perhaps even has automatic control (e.g., via door contact or motion sensor). I’m interested both in ready-made lighting kits designed specifically for Metod, as well as proven DIY solutions using LED strips or light bars. It would also be helpful if someone could share tips on power supply, installation, and cable routing inside the cabinet to ensure everything looks neat and is safe. Are there particular products or methods that work especially well here? I look forward to your experiences and recommendations!
BELLA34
27 Jul 2021 18:45
I would recommend using 12V LED strips, as they are very flexible and produce little heat. For the power supply, you can hide a small transformer under the cabinet base. Installing a door contact switch is also very easy, so the lighting only turns on when the door is open. Simply route everything neatly with cable ties, and that’s it.
Helga
27 Jul 2021 19:12
For additional information: LED strips with a warm white color temperature (around 3000K) are especially suitable for interior lighting in IKEA Metod cabinets to create a pleasant light. The 12V system is generally preferable because it is safer and places less strain on the wiring. Some suppliers offer lights specifically designed for Metod, usually with an integrated switch function for the door opener. Careful cable management should be done using cable clips or adhesive tape to prevent damage. Also, pay attention to the quality of the power supply to avoid flickering effects.
V
vincent46
27 Jul 2021 20:41
I can confirm that! At first, I was worried about the installation, but after setting up the strips, I’m really impressed. It feels much more inviting, especially when you open the cabinet door in the evening. Initially, I was unsure about the power connection, but with a simple power supply and the door sensor, it was really manageable.
You really shouldn’t underestimate that – I had loose cables at first, which was not only unsightly but also dangerous. So definitely make sure to secure them well!
LANICOLE
28 Jul 2021 08:07
Here is a brief tutorial on lighting IKEA Metod cabinets:
- Lighting choice: LED strips with 12V are ideal due to low heat generation and flexibility.
- Installation location: Inside, on the ceiling or sides of the cabinet, ensuring even light distribution.
- Power supply: Store a small 12V power adapter in the base or bottom of the cabinet.
- Switching: Best done with a magnetic door contact switch, easily mounted on the cabinet door and frame.
- Wiring: Secure neatly with cable clips on the cabinet floor or sides. Transparent or white cables are often preferred to keep them discreet.
Common mistakes include cables that are too short or poorly mounted strips that come loose or look untidy. It is also important to clean the surfaces before gluing to ensure good adhesion.
Conclusion: This way, you get durable, attractive, and safe interior lighting that is easy to control and enhances the appearance of the cabinet.
