ᐅ How can I equip IKEA BESTA with LED lighting?
Created on: 27 Apr 2020 13:27
jamalba
jamalba
27 Apr 2020 13:27
Hello everyone, I am currently planning to equip my IKEA BESTÅ furniture with LED technology to achieve modern, pleasant lighting that is both functional and aesthetic. I have several questions: Which LED lighting solutions are particularly suitable for integration into BESTÅ, such as LED strips, LED panels, or individual spotlights? How difficult is the installation and wiring, especially if you want to operate the furniture flexibly with a plug instead of hardwiring it? Are there good recommendations for appropriate power supplies or dimmers that can be installed in a living area without extensive electrical knowledge? And finally, I am interested in any experiences regarding heat generation and the durability of LED solutions in closed cabinets like BESTÅ. I look forward to helpful tips, including details that are easy to overlook. Thanks in advance!
GiRoyce
27 Apr 2020 14:05
LED strips are especially suitable for BESTÅ because they can be cut to size and are slim – this makes it easy to stick them into shelf corners or on the inside of the cabinet frame. Look for self-adhesive strips with 12V DC power, as this is safer and easier to handle.
jamalba schrieb:
How difficult is the installation and wiring, especially if you want to operate the furniture flexibly with a plug rather than a fixed connection?
This is quite manageable: you can power the wiring via an external 12V power supply connected to a wall outlet. The cables of the LED strips can be connected using plug connectors or terminal blocks, which allows for some flexibility. It’s best to route the cables neatly along the back panels.
You don’t need to be a professional for the installation, but some basic DIY skills are helpful. Immediate electric shocks are very unlikely if you stick to the 12V system.
jamalba schrieb:
Recommendations for suitable power supplies or dimmers that can be installed in a living area without extensive electrical knowledge?
There are ready-made 12V power supplies with different wattages – you should choose the power supply according to the length of your LED strips (for example, 12V/2A or higher). Dimmers for LED strips are also available as inline versions and are very easy to install.
jamalba schrieb:
Experiences regarding heat generation and durability of LED solutions in enclosed cabinets like BESTÅ?
LEDs produce little heat, but good heat dissipation is still important. The aluminum backing of LED strips helps with this. The furniture should not overheat, so it can be helpful to leave small ventilation holes if it’s a tight fit inside.
kulau
28 Apr 2020 08:48
I’m glad you’re exploring the LED setup for the BESTÅ cabinet, as these pieces are wonderfully modular but require some tricks when adding electronics.
First, I recommend carefully planning which areas you want to illuminate – just the bottom, shelves, back panel, or even the inside surfaces of the doors. For even lighting, LED strips with a high density (e.g., 60 LEDs/meter (18 LEDs/foot)) work best, as they provide a smoother light.
Regarding wiring: If you want a flexible solution, I suggest a 12 V DC power supply with sufficient power reserve (calculate watts by multiplying the power of individual LEDs by the total length) and connections via JST connectors or terminal blocks. It’s important to pay attention to polarity; LED strips usually indicate this with ‘+’ and ‘–’ signs.
For dimmers, there are two types – PWM dimmers (pulse-width modulation) and voltage dimmers. I recommend PWM dimmers for LED strips, as they extend lifespan and prevent flickering.
To avoid heat buildup, mount the LED strips on aluminum profiles with cooling fins. Even if the BESTÅ cabinet is closed, the aluminum profile acts as a heat sink. Without this, over time you may experience brightness loss and color shifts.
One handy tip: Use painter’s tape to stencil and temporarily fix the LED strips before final adhesion, which makes precise placement easier.
Finally, if you want the cabinet doors to control the lighting, a magnetic switch or a small motion sensor can be an interesting addition. A 12 V system works well for this and is easy to install.
If you like, I can also draft a detailed shopping list and wiring diagram to approach the installation in a well-structured manner.
SAWYERR
28 Apr 2020 10:16
12V LED strips are practical and safe for BESTÅ. Use simple plug-and-play power supplies and dimmers for control. Installation is done with self-adhesive strips, and wiring through connectors. Heat protection with aluminum profiles prevents issues. This way, the system is durable and flexible.
