ᐅ How can I easily retrofit Ikea Metod drawers with soft-close mechanisms?
Created on: 1 May 2015 18:37
Saul61
Saul61
1 May 2015 18:37
some time ago I purchased Ikea Metod kitchen cabinets and I am very satisfied with them. However, the drawers do not have a soft-close feature, which I would now like to retrofit. My question is: What is the easiest and most straightforward way to add soft-close functionality to Ikea Metod drawers?
I am especially interested in whether there are good retrofit kits that can be installed directly onto the existing drawer slides, or if it is better to replace the entire drawer slides.
Important factors for me are: simple installation without major modifications, compatibility with the existing Metod drawers, and a permanently reliable soft-close function.
Perhaps someone here has practical experience or can recommend products that have proven effective and explain the exact installation process.
I look forward to your feedback!
Sepele
1 May 2015 19:05
Hello Saul61,
I would like to provide a more detailed response to your question, as retrofitting soft-close on Ikea Metod drawers is definitely possible, but there are a few important points to consider:
- There are so-called soft-close retrofit kits that can be mounted on the existing drawer slides. These usually consist of a damper and a catch mechanism, which are attached to the side of the drawer.
- It is crucial that the kits are compatible with the existing Metod telescopic slides. Be sure to check the manufacturer's specifications for this.
- Alternatively, you can replace the entire drawer slides with soft-close slides from Ikea or other suppliers. Although this is somewhat more work, it is very reliable.
- During installation, the drawer box should be removed and the dampers mounted on the inside of the slides. This usually does not require special tools, just a screwdriver.
Common mistakes include incorrect positioning of the dampers or the drawer not being properly aligned, which causes the soft-close function to not work correctly.
In summary: If you have some DIY skills, retrofitting with kits is quite feasible, but for maximum reliability, I would recommend completely replacing the drawer slides.
If you want specific product suggestions, I can look into that for you.
Sinan-meo
1 May 2015 20:42
I agree with Sepele’s recommendation.
It makes sense to replace the original drawer slides with soft-close versions if you want a durable and satisfying solution.
Ikea itself offers soft-close slides for Metod that usually fit without any issues. The mounting hardware matches the drill holes of the Metod cabinets exactly.
Retrofitting with upgrade kits is cheaper, but you can often tell in their function that it’s a compromise—especially with heavier drawers.
My tip: Order one or two soft-close slides to test. If you manage the installation, you can convert all the drawers and have a very clean solution.
LANELE
2 May 2015 08:12
Simplest solution: buy Ikea soft-close drawer slides and replace the existing ones.
No modification to the drawer necessary, just unscrew the old slides and screw in the new ones.
Fits perfectly on Metod.
Installation time per drawer is about 10 minutes.
MAVERICKKA
2 May 2015 10:53
Saul61 schrieb:
How can I easily retrofit Ikea Metod drawers with soft-close functionality, preferably with minimal effort?
I consider retrofitting with conversion kits to be a compromise solution that is often underestimated. Frequently, it results in limited drawer movement, and the durability of the dampers is often lower compared to original soft-close drawer slides.
The idea of simply attaching to the existing drill holes sounds good, but in practice it does not always work smoothly, especially when the drawers are heavily loaded.
I would be interested to hear if anyone here has long-term experience with retrofit kits, particularly regarding load capacity and any potential issues during installation.
Sepele
3 May 2015 17:26
MAVERICKKA schrieb:
I’m interested to know if anyone here has long-term experience with retrofit kits, especially regarding durability and potential issues during installation.
From my experience, retrofit kits can last several years if installed properly. However, their durability is generally lower compared to original soft-close drawer slides.
It’s also important that the damper is not too weak, particularly if you have heavy cutlery or pantry drawers. There are different damper strengths available.
A common mistake is not following the kit instructions carefully, for example, incorrectly setting the distance to the drawer front edge. This results in poor closing performance.
My advice for proper retrofitting:
- Check beforehand if the drawers themselves are stable enough to handle the extra load
- Pay attention to precise installation and adjustment
- For heavier drawers, consider switching to full-extension slides instead.
Overall, retrofitting with retrofit kits is worthwhile for a smaller budget if you are patient during installation. For better quality and long-term use, however, complete soft-close drawer slides are the better choice.
