ᐅ How can I customize IKEA BESTA fronts using wallpaper or fabric?
Created on: 10 Sep 2024 08:37
Lis32Hello everyone,
I am currently exploring the idea of customizing my IKEA BESTÅ fronts to make them more unique and homely. I’m particularly interested in how to enhance these fronts using wallpaper or fabrics without affecting their functionality or durability. Specifically, I would like to know which types of wallpaper (non-woven wallpaper, vinyl, traditionally painted wallpaper, etc.) or fabrics work best, what to consider during application, and how to achieve a clean and long-lasting surface.
I’m also curious about which adhesive methods or fastening techniques you have had good experiences with. Are there any special preparations for the fronts that should definitely be observed? I would also appreciate any tips on potential problems to avoid, such as issues affecting hinges or handles.
I thought a detailed exchange on this topic would be helpful for everyone wanting to personalize their furniture a bit more. Looking forward to your tips and experiences!
Basically, I recommend using thin, well-adhering types of wallpaper, such as non-woven wallpaper or self-adhesive films, to decorate IKEA BESTÅ fronts with wallpaper or fabrics, as these are easier to work with and interfere less with the mechanics. It is important to prepare the fronts beforehand with a lightly sandable, matte primer to ensure optimal adhesion of the adhesives.
For fabrics, thin, stretchable materials should be chosen. Spray adhesive or double-sided tape works best as glue, as these allow flexible application and a clean surface.
Tips:
- Be sure to remove hinges and handles before decorating.
- Cut the wallpaper or fabric precisely to size, avoiding any overlap.
- After applying the covering, seal the surface with a matte clear coat to increase durability and abrasion resistance.
Issues like warping of the fronts mainly occur when using moist adhesives or materials that are too thick.
Tips:
Hi Lis32,
I’m happy to provide a step-by-step approach for applying wallpaper or fabric to BESTÅ fronts, as adhesive mistakes often occur in DIY projects.
1. Preparation:
- Remove the fronts from the cabinet and take off handles and fittings.
- Lightly sand the surface (e.g., 220 grit) to create a rough texture for better adhesion.
- Clean off dust using a microfiber cloth and, if needed, isopropanol.
2. Material selection:
- For wallpaper: non-woven (fleece) wallpaper is ideal because it doesn’t expand and is easy to apply.
- For fabric: thin, smooth cotton fabrics or woven backing materials.
3. Adhesive:
- Properly dosed spray adhesive is often the best choice for fabrics.
- For wallpaper, standard wallpaper paste or diluted wood glue suitable for photovoltaic systems can be used.
4. Application:
- Apply adhesive evenly either on the substrate or on the back of the wallpaper/fabric.
- Smooth the wallpaper or fabric quickly and carefully remove any air bubbles.
5. Finishing:
- After the adhesive is fully dry, seal the surface with a water-based clear coat; it should be matte or satin.
A common mistake is applying the adhesive too late or too thickly, which leads to bubbling or wrinkling.
1. Preparation:
3. Adhesive:
4. Application:
5. Finishing:
Wow, a very exciting topic! Some time ago, I covered my BESTÅ fronts with fabric as well and am absolutely thrilled with the result! 😊
I used a lightweight cotton fabric with a bit of texture and applied spray adhesive. The most important part was removing all handles and carefully smoothing the fabric to avoid any wrinkles. After that, I sealed everything with a matte clear coat to protect the fabric well.
Tip: If you want to redesign your fronts more often, use a removable spray adhesive instead of a permanent one. This way, you can simply peel off the fabric and replace it after some time!
Don’t be discouraged if it’s not perfect right away – DIY is fun, and each front becomes a unique piece!
As a supplement: When selecting the fabric and wallpaper, special attention should be paid to the thickness. Materials that are too thick can affect the cabinet mechanism, as the front frames can easily become deformed.
For applications with wallpaper, it is also advisable to apply a protective film over the wallpaper to make the surface more resistant to moisture and dirt. This is especially important if the furniture is located in kitchens or living areas.
Furthermore, it is recommended to carefully work the edges of the fronts with fine sandpaper so that the fabric or wallpaper fits cleanly and without overhangs at the corners.
PeoDaniel11 Sep 2024 07:59Hello everyone,
I would like to patiently revisit the topic of working especially with fabrics on the reverse side and at the corners. Problems often arise from applying glue in the corners, which can overly saturate the fabric fibers there and cause deformations or wrinkles. To avoid this, I recommend:
- Cutting the fabric very precisely and generously at the corners and edges.
- First fixing the fabric with adhesive in the central area.
- Then applying the glue very sparingly in the corners using a small brush or sponge and smoothing the fabric carefully there.
Also, regarding durability: Please test the clear coat or other sealants beforehand on a sample piece to assess any color or texture changes. This is especially important for colored fabrics.
