ᐅ How can I customize IKEA HEMNES shelves?
Created on: 22 Dec 2016 08:43
tutau
tutau
22 Dec 2016 08:43
I recently purchased a Hemnes shelving unit from IKEA and am considering customizing it to better suit my interior style. My question is: How can I creatively and practically personalize IKEA Hemnes shelves without compromising their stability or functionality?
I’m looking for concrete suggestions, such as painting, adding decorative elements, or modifications involving other materials. What proven materials, tools, and steps are recommended for such projects?
Has anyone here already had experience upgrading or modifying Hemnes shelves, for example through repainting, adding extra compartments, or installing special handles or lighting?
My main goal is to transform the shelf into a unique piece visually, while keeping it sturdy and fully functional.
Thanks in advance for your tips and advice!
poted
22 Dec 2016 11:17
Hello tutau,
You’re asking a great question, as customizing a HEMNES shelf can really make a big difference when done right. First, you should consider how extensive the changes should be: Do you want to update only the surface, or also expand its functionality?
For painting, I recommend lightly sanding the piece first to ensure better adhesion of the new paint. It’s important to thoroughly remove all dust afterward. I usually use sandpaper with a grit of 120 to 180. Then, apply a primer suitable for wood or veneered surfaces.
If you choose to use paint, acrylic lacquer is particularly recommended because it is flexible and less prone to cracking. Apply several thin coats, allowing each to dry well.
As a practical upgrade, you can integrate power strips or install LED light strips inside the shelf—especially if you use it as a bookcase or media shelf. Make sure to neatly arrange the cables, preferably with cable channels, to maintain a clean look.
Another idea is to replace the back panel with a thin colored or patterned MDF board. This gives the shelf new depth and adds a personalized touch.
Additionally, you can attach handles or small hooks for hanging if the side panels are sturdy enough. For this, I suggest brass-colored or matte metal handles that suit the Scandinavian design of the HEMNES range.
Finally, I’d like to ask: What materials and tools do you already have available, and roughly how much time do you want to invest? This way, the whole project can be better tailored.
naudan
23 Dec 2016 13:52
poted schrieb:
For painting, I recommend lightly sanding the piece of furniture first to ensure better adhesion of the new paint layer.
This is a very important point because without sanding, paint can easily peel off, especially on painted surfaces like those of the HEMNES.
Another useful tip: if you prefer a matte finish, chalk paints are a good option. They often require little preparation and create a nice velvety surface with a vintage character.
On the practical side, I have had good experience complementing internal shelves with decorative boxes or baskets. This keeps the shelving tidy and adds structure at the same time.
Magnetic strips on the side panels or a small chalkboard (for example, painted with chalkboard paint) can also make the shelf multifunctional, especially in home offices or children’s rooms.
If you like, you can also apply wallpaper remnants or self-adhesive films to the back panel to add color accents. Just be careful not to make the back panel too thick so the shelf still fits well against the wall.
poted
24 Dec 2016 09:36
naudan schrieb:
One more good tip: If you prefer a matte finish, chalk paints are a great option.
Absolutely, chalk paint is excellent because it is very versatile and relatively easy to apply. Beginners, in particular, find it manageable.
I would just add that for heavily used surfaces, it is advisable to seal the finish with a matte wax or clear lacquer to make the surface more durable.
naudan schrieb:
Magnetic strips on the side panels or a small chalkboard (e.g., painted with chalkboard paint) can also make the shelf multifunctional
I can also recommend that; magnetic strips are easy to install and offer great uses, for example, for notes or small tools in a workshop.
If you’re open to experimenting, tutau, it might also be interesting to replace some shelves with other materials – such as glass or wooden boards with a different finish. This significantly changes the feel and look but requires some craftsmanship when measuring and fitting.
