ᐅ How can I customize the IKEA Brimnes for the guest room?
Created on: 12 Apr 2022 08:37
turhan
turhan
12 Apr 2022 08:37
Hello everyone, I’m planning to customize the IKEA Brimnes guest bed for our guest room because I find the original design a bit too plain and want to make better use of the storage space. Specifically, I’m interested in ways to enhance the appearance of the furniture while also making functional adjustments—such as changing the color, adding accessories, modifying the handles, or reorganizing the internal storage. Maybe some of you have experience with modifications or are handy and can offer tips on how to reinforce or stabilize the construction, especially if the bed will be used for longer guest stays. I’m also curious about possible combinations with other IKEA products that complement the Brimnes and help make the guest room feel more comfortable overall. Looking forward to your creative ideas and suggestions!
raulso
12 Apr 2022 09:48
Hey turhan, great question! The Brimnes already has a clean look, but with a bit of color and some stylish handles, it really becomes an eye-catcher. I painted the white fronts with furniture paint in a petrol blue – it really stands out and feels more high-quality. I also replaced the standard handles with brass ones, which adds an elegant touch.
For storage: foldable fabric boxes or narrow baskets work well to organize stuff. And if you use the bed often, it’s worth adding Teflon tape to the drawer runners so they slide more smoothly and don’t squeak when opening and closing.
Combinations? A Malm nightstand next to it looks great and adds some variety. A nice rug and a few colorful cushions on the bed create a cozy atmosphere. This way, the guest room isn’t just practical, but also comfortable! Good luck with your project!
Lis53
12 Apr 2022 11:04
For customizing the IKEA Brimnes guest bed, I recommend the following structured approach:
- Surface: Remodeling with a comparable furniture paint is possible. Start by applying a primer to ensure good adhesion. Then paint in the desired color.
- Handles: Replacing the handles is straightforward since they are screwed on. Pay attention to measurements to avoid having to relocate holes.
- Storage: For better interior organization, I suggest modular storage boxes and dividers that fit the drawer size. Alternatively, removable containers can also be used.
- Stability: The bed is designed for guests; however, additional reinforcements on the center rail (for example with metal brackets) can improve durability.
- Accessories: Matching bedside tables from the Brimnes series or related product lines create a cohesive look.
Please note that repainting may void the manufacturer’s warranty. All materials should be suitable for indoor use to avoid harmful substances. In summary, the Brimnes system offers good customization options but requires some DIY skills for modifications.
neoren
12 Apr 2022 14:22
For the guest room, you can easily improve the Brimnes:
- Replace the handles for a better look
- Organize storage with boxes
- Paint it to add your own color
- Install metal brackets to prevent sagging
That's all it takes.
Nofege
13 Apr 2022 10:59
Hello turhan, here is a simple step-by-step guide to effectively modify the IKEA Brimnes guest bed:
1. Preparation: Disassemble the bed and thoroughly clean all surfaces.
2. Replacement handles: Measure the existing drill holes and look for handles with the same hole spacing. This way, you avoid drilling new holes, which helps maintain stability.
3. Painting: If you plan to paint, I recommend fine sandpaper (e.g., grit 220), wood primer, and acrylic furniture paint. Apply several thin layers and allow each to dry well.
4. Storage organization: Small plastic or fabric boxes work very well inside the drawers. Make sure the dimensions fit so the drawers can close without problems.
5. Increase stability: A common mistake is not reinforcing the center support beam when the bed is used frequently. Metal brackets from the hardware store can be attached with wood screws without affecting the appearance.
Summary: Without major construction work, you can enhance the Brimnes visually and functionally. Simple tools are usually sufficient, allowing you to create a customized guest room with high practical value. If you have specific questions about materials or tools, I’m happy to help!
