ᐅ How can I creatively enhance IKEA Besta fronts using fabric or wallpaper?
Created on: 23 Jul 2024 10:03
Ployigit10P
Ployigit1023 Jul 2024 10:03Hello everyone,
I am planning to upgrade my IKEA Besta fronts with fabric or wallpaper to give them a more personalized and cozy look. I am particularly interested in creative and durable methods that do not damage the material and are ideally reversible. For example, I am considering attaching fabric with special adhesive or covering the fronts with thin wallpaper, but upholstery or sewing in frame structures could also be options.
What are your experiences and tips regarding the following points?
- Which adhesive or technique works best to attach fabric neatly and permanently to Besta fronts?
- Which types of fabrics are especially suitable (e.g., cotton, linen, synthetic)?
- How should I handle pattern alignment or cutting of the wallpaper to ensure a neat appearance?
- Are there special preparations or primers for the fronts that make the process easier or improve durability?
- What are the most common mistakes to avoid?
I look forward to your experiences, preferably with detailed descriptions, as I really want to achieve a professional result. Thanks in advance!
Hello Ployigit10,
your topic is very interesting and technically not that simple. I’m happy to provide a detailed assessment, focusing on step-by-step methods.
Generally, for adhering fabric to smooth MDF or particleboard fronts like those commonly used in Besta units, I recommend special contact adhesives based on water or solvent. These ensure a flexible yet durable bond without wrinkles. It is important to apply the adhesive in thin but even layers on both the fabric and the front — before pressing together, let the adhesive dry slightly (usually 10–15 minutes) to improve adhesion.
Fabric types: Cotton or linen are perfect if you want breathable materials with a light texture. Synthetic fabrics such as polyester are very durable but tend to have reflections and can form bubbles if lower-quality adhesives are used. Tip: Wash fabrics beforehand to avoid shrinkage.
Regarding wallpaper: It is advisable to use thin non-woven wallpapers, as they remain flexible and are relatively easy to handle. For pattern alignment, I generally work with a grid measurement and cutting aids (e.g., rotary cutter on a cutting mat). Ensuring that the pattern is aligned at right angles on the fronts is essential for a professional result.
Preparation: The surface must be grease-free, so clean it in advance with a mild detergent and let it dry. Priming with white acrylic paint can be useful if the front is dark or textured, as this helps the adhesive bond better and makes the pattern stand out vividly.
Common mistakes I often see:
- Applying too much adhesive (which dissolves fabric or wallpaper)
- Impatience: pressing down immediately without drying time
- Insufficient smoothing, causing bubbles and wrinkles
I hope this helps you as a start. Which fabric or wallpaper types do you already have in mind? Are you planning a full-surface design or a combination with other materials?
Interesting thread! To be honest, I often find most embellishments of Besta fronts with fabric or wallpaper a bit overrated. Sure, it can be done, but it often looks worn out again after a short time or comes across as cheap.
That sounds good, but honestly: How durable is it really with so much everyday use and frequent opening and closing of the doors? Also, the effort is huge, especially if, as you say, you want to work very precisely.
I would rather suggest looking into films or vinyls – much more durable and also visually less prone to wear over time. Fabric or wallpaper can be nice, but as soon as moisture gets on it, you’re in for the next challenge.
Of course, if someone wants to try it and is handy, all the best to them. I just wouldn’t recommend it to everyone.
Domau0 schrieb:
In general, I recommend using special contact adhesives based on water or solvent for fixing fabric onto smooth MDF or particleboard fronts, as commonly found with Besta.
Ployigit1024 Jul 2024 09:45Thanks in advance for your answers and assessments, they help me a lot!
@Domau0: I find your step-by-step explanation very helpful, especially the tip about priming and the drying time of the adhesive. Right now, I’m leaning toward cotton fabrics because I value their natural feel, but I will include your recommendation to consider non-woven wallpaper format during the wallpaper check.
@GALEO4: Your criticism is understandable, especially regarding durability and maintenance. I still don’t like films that much because they often seem too artificial to me. However, I’m curious about which adhesives you have used, or do you have specific experience with fabric on IKEA furniture?
In response to your question, Domau0: I’m thinking about large-scale covering of individual fronts, perhaps combined with small inserts of coarse linen fabric to highlight texture. A mix of fabric and wallpaper could have an interesting effect. Has anyone ever implemented a frame structure or decorative moldings using fabric coverings? I see this as a potential accent.
I look forward to more experiences and tips.
The discussion here is very informative. I would like to add some facts about the preparatory work that Ployigit10 already mentioned:
- Surface preparation of Besta fronts is very important. Since they are usually melamine-coated or covered with foil, lightly sanding the surface with fine sandpaper (grit 200-320) is advisable to improve adhesion. Afterwards, remove all dust thoroughly.
- For adhesives, I strongly recommend solvent-based contact adhesives such as Pattex Contact or specialized fabric glues from professional manufacturers. For wallpaper, a modified wallpaper paste, such as dispersion adhesive, can also work.
- The stretchability of the fabric should be considered. I recommend using firm, low-stretch textiles to avoid tension building up during everyday use.
- Precision tools are essential for cutting, such as sharp fabric scissors or a rotary cutter with a cutting mat. Special attention is needed for corners and edges; small cuts in the fabric can help prevent creasing.
- Options like attaching decorative moldings or creating an overhang at the edges work very well to elegantly hide fabric edges. This also adds extra durability.
- It is also worth mentioning easy-care surface sealants as protection after gluing, such as fabric waterproofing sprays or transparent protective coatings for furniture.
In summary, I advise careful planning, testing small areas, and choosing suitable materials. I can also provide product names and sources if desired.
