ᐅ What is the best way to use BILLY shelves in small alcoves?
Created on: 27 Oct 2023 14:23
DEOVICTO47
DEOVICTO47
27 Oct 2023 14:23
Hello everyone, I have a question about using IKEA BILLY bookcases in small niches I have in my apartment. My niches are about 80 cm (31.5 inches) wide and 200 cm (78.7 inches) high, so rather narrow and tall, which makes installing regular shelves difficult. I want to create as much storage space as possible without overcrowding the niche or wasting space due to inappropriate shelf widths. My specific question is: How can I best use BILLY bookcases in such narrow niches to maximize storage while maintaining a neat, aesthetically pleasing overall appearance? Are there any special tips, modifications, or accessories you would recommend for using BILLY efficiently in tight, tall niches? Thanks for your advice!
KUDAISY
27 Oct 2023 15:16
Hello DEOVICTO47,
Regarding your issue with BILLY shelves in narrow niches, I can share some tips that have worked well for me. In general, BILLY shelves are flexible, but the standard widths (80 cm, 40 cm) are often a bit too wide for narrow spaces.
1. Combine components: You can place two BILLY 40 units (40x28x202 cm) side by side if the niche is 80 cm (31.5 inches) wide. It is important to connect them to ensure stability.
2. Adjust or remove back panels: Sometimes removing or modifying the back panel helps you fully utilize the niche and allows the shelf to sit flush against the wall.
3. Customize shelves: Trim the shelves if necessary to make the most of the niche’s depth.
4. Additional storage above: Since the height of 200 cm (79 inches) is ideal for BILLY, you can use the top shelf for items you use less frequently. Using suitable boxes or baskets keeps it looking tidy.
5. Consider doors carefully: In tight niches, doors can be cumbersome. Curtains or open shelving can help keep the space feeling open.
Summary: Use two narrow BILLY shelves, securely connect them, and adjust the back panel and shelves as needed. This will maximize your storage space. If you’re still unsure, you can post the exact measurements.
I hope this helps!
Matthewt48
27 Oct 2023 16:02
Hello DEOVICTO47,
I would like to add to what @KUDAISY mentioned. Especially for small niches, it’s advisable not just to place the shelves in the space, but to use some simple tricks to make better use of the area.
- Adjust shelf height: BILLY shelves can be customized by adding feet or plinths. This lets you calibrate the height perfectly to fit your niche.
- Flexible use of shelves: By adding extra or removable shelves, you can better store smaller items.
- Adjust side panels: In some cases, trimming the side panels helps the shelf fit exactly into the niche.
- Lighting: Consider subtle LED lighting inside the niche to enhance visibility and create an attractive look.
Besides functionality, appearance also matters to prevent the niche from feeling cramped.
Good luck with your project, and feel free to ask if you have any questions!
SONLIS
27 Oct 2023 18:47
I would like to add one more aspect to the discussion: stability.
KUDAISY schrieb:
It is important that you connect them to ensure stability.
Especially for shelves in alcoves, it is crucial to secure them against tipping, not just connect them. A solid attachment to the back wall or using brackets on the alcove walls prevents dangerous accidents, particularly when the shelves are tall and narrow.
Additionally, I recommend choosing shelves with a high load capacity when depth is limited. Standard shelves often support only up to 15 kg (33 lbs), which can quickly become a problem with fully loaded shelving.
Overall, precise planning of dimensions and loads is absolutely necessary.
andre3
28 Oct 2023 09:21
I would like to add to the previous points and address some technical details.
BILLY shelves come standard with wall brackets, which are especially useful when installing in recesses. For your described recess dimensions (80 cm wide, 200 cm high [31½ inches wide, 78¾ inches high]), I recommend the following:
- Use the 40 cm width as a base, since two placed side by side will exactly match 80 cm.
- Check the depth of the recess and, if possible, opt for the 28 cm depth version as it protrudes less into the room.
- Make sure the shelves stand on a level surface to ensure stability.
- Adjust the back panels by trimming or omitting them if you have access to the recess’s back wall.
- To connect the shelves, it is best to use metal brackets and screws rather than adhesive bonds.
Combining these measures ensures optimal use of the recess with maximum stability and functionality.
farGlen
28 Oct 2023 10:34
I would also recommend paying attention to appropriate lighting. Especially in narrow niches, it can otherwise feel quite dark. LED strips on the shelves are inexpensive and provide better visibility.
Additionally, paint the interior in light colors to make the small space appear more open.
