ᐅ How can I modify Ikea Metod cabinets during renovations?
Created on: 25 May 2023 08:17
lonike
lonike
25 May 2023 08:17
Hello everyone, I am currently planning a major renovation in my apartment and want to modify and reintegrate my Ikea Metod kitchen and storage cabinets. Specifically, I am looking for ways to adapt the Metod cabinets flexibly to changed room conditions, for example, when walls are moved or shortened and the cabinet size no longer fits.
I am aware that Ikea offers some extension parts, but I am looking for practical and cost-effective methods to modify Metod cabinet modules or sensibly expand them with accessories to optimally fit the cabinets into unconventional room layouts.
I am especially interested in user experiences with custom modifications, such as shortening side panels, installing additional shelves, replacing the back panels, or combining modules into unusual shapes.
Additionally, it would be helpful to get advice on the tools needed and common mistakes to avoid when customizing them yourself.
Thanks in advance for your advice!
warrenka57
25 May 2023 09:05
This topic is personal to me because I tried modifying Ikea Metod cabinets during a renovation last year, and I know how frustrating it can be.
lonike schrieb:
I’m especially interested in whether anyone has experience with custom modifications, such as shortening side panels, adding extra shelves, replacing the back panels, or combining modules into unusual shapes.
At the time, I carefully shortened the side panels using a jigsaw – this basically works, but you need to measure very precisely and be careful not to damage the joints. One mistake I made was underestimating the load-bearing capacity, and after a few months some of the shelves gave way.
I would recommend always using edge banding or strips where you cut, otherwise the finish gets rough and the structure becomes unstable.
Does anyone have tips on how to achieve a neater look?
RENMA
25 May 2023 10:42
For adapting Ikea Metod cabinets during renovations, based on my own experience and research, I recommend the following structured approach:
- Take precise measurements of the new room dimensions before preparing the modules
- Plan the cabinet combination considering the standardized Metod widths of 20, 40, 60, 80 cm (8, 16, 24, 31.5 inches)
- Side panels can theoretically be shortened, but this must be done with appropriate reinforcement since stability may be compromised
- Back panels can easily be replaced with thinner boards or reinforcements, which can help compensate for uneven walls
- For special cases, custom-made filler pieces are a good option to harmoniously adapt cabinets to the wall
- Tools: jigsaw with a fine blade, router, sandpaper, edge banding or suitable trim strips
- Avoid mistakes: inaccurate measuring, cutting too deeply into load-bearing parts, and insufficient reinforcement should be strictly avoided
This systematic procedure is the best way to ensure a clean, professional result.
faso31
25 May 2023 11:07
I think it is important to fundamentally question whether the Ikea Metod system is really the best fit for the intended room layout when making such modifications.
RENMA schrieb:
Side panels can theoretically be shortened, but this requires proper reinforcement because stability can be compromised
This sounds like a key point to me: If a modification weakens the basic structure, it might make more sense to plan for completely new modules or custom cabinetry instead.
Does anyone have concrete experience with how stability changes when Metod components are shortened, for example by 5cm (2 inches) on the side? Are there comparison values available? I imagine that the area around the drill holes and connectors is already a weak spot. Perhaps it would be better to use overlays or filler pieces instead of shortening?
teyosef
25 May 2023 13:19
Here is a brief guide for customizing Metod cabinets during renovations:
1. Planning: Accurately measure rooms and cabinet dimensions, and document any future wall offsets.
2. Modifying side panels:
- If shortening is necessary, cut only with a clean jigsaw cut.
- Then reinforce the cut edges with edge banding or wood glue and battens.
- Assemble the cabinet securely and check all connections thoroughly.
3. Back panels: Often, replacing them with sturdy, thinner versions can compensate for uneven surfaces.
4. Shelves can also be individually adjusted or added; IKEA offers additional options for this.
5. Connecting modules: Secure with special brackets or connector plates.
Make sure that all modifications do not reduce the load-bearing capacity of the components. I also recommend using tools with precise cutting control and working patiently. Mistakes like cutting too quickly or lacking reinforcement can easily cause problems.
I’m happy to offer advice if you have specific measurements or room plans.
Davidleo
26 May 2023 07:53
Wow, such an interesting topic! I just modified my Metod cabinet wall because I had to shorten a corner in the room.
teyosef schrieb:
If shortening is unavoidable, cut only with a clean jigsaw cut
Yes, that’s really true – without a clean cut, the result looks messy, and it’s almost impossible to avoid ugly edges. After shortening, I also glued mounting strips to the inside, which provides really good support!
Definitely: go for it! Especially if you follow the tips from the previous posts, the whole process is easier than you think. And the feeling of adjusting your own furniture to fit is very satisfying 🙂
