ᐅ How can BILLY shelves be protected from damage in damp rooms?
Created on: 26 Mar 2023 14:07
ploju
I plan to install Billy shelves from IKEA in a damp room (e.g., bathroom or basement), but I am unsure how to best protect them from moisture damage. The shelves are made of particleboard with a melamine coating, which can easily swell when exposed to moisture.
I am especially interested in practical methods or additional materials you would recommend to protect Billy shelves in damp rooms over the long term. Are there specific varnishes, sealants, or modifications that have proven effective? What experiences have you had to prevent the wood from warping or swelling?
I look forward to your tips and advice!
ploju
27 Mar 2023 09:57
Nakar33 schrieb:
Has anyone had experience with replacing the back panel with water-resistant MDF boards? Does this offer any advantages?
Thanks, that’s a very good point! I’m wondering if it might be better to completely replace the thin particleboard back panel with a moisture-resistant alternative like MDF or OSB, which might hold up better.
The room has a really high humidity of around 70% - 80% and is not heated, more like an unheated basement.
What about the paint or varnish layers – is it better to apply them before or after assembly? And what about the screw holes – do they also need to be treated? I want to avoid any possible weak spots.
Dilen
27 Mar 2023 10:24
ploju schrieb:
What about the paint layers – should you paint before or after assembly?
It’s best to paint before assembly. I recommend the following procedure:
- Apply several thin coats of water-repellent paint generously to all parts from every side, especially edges, the backside, and screw holes.
- Sand lightly between each coat to ensure adhesion of the next layer.
- After assembly, apply a final coat to all visible surfaces to enhance protection.
Nakar33 schrieb:
Experience with water-resistant MDF boards as backing panels
That actually makes sense. Moisture-resistant MDF boards (often coated with melamine or similar) swell significantly less than standard particle boards. When replacing them, make sure to mount them evenly to keep the shelf stable.
ploju schrieb:
Treating screw holes
Yes, moisture can penetrate there in particular. I recommend sealing the screw holes with paint or wood preservative before assembly to provide additional protection.
Also, keep in mind that the screws themselves can rust; using galvanized or stainless steel screws reduces this risk.
Paunon
28 Mar 2023 08:13
Keep the shelf raised off the floor.
Simply painting is not enough if the humidity level is constantly high.
Prioritize dehumidifiers and improved ventilation.
nubar
28 Mar 2023 11:23
In conclusion, I recommend considering an alternative material instead of a particleboard BILLY shelf, especially in areas with persistent moisture.
If this is not desirable, applying a reinforced surface finish with specialized marine varnishes, replacing the back panel with water-resistant boards, and raising the base significantly on feet are the best measures.
Additionally, regular checks for moisture damage and maintaining an indoor temperature with consistently low humidity levels are crucial. This will help minimize the risk of damage over time.
