I am planning to install an IKEA KALLAX shelving unit in a tropical environment, specifically in a living area that consistently has high humidity levels of around 70 to 80%. I am wondering if this constant tropical humidity could damage the MDF material of the KALLAX shelves – for example, causing it to swell, permanently warp, or possibly lead to mold growth.
Does anyone have experience with KALLAX or similar shelving units exposed to consistently high humidity? Are there any special coatings or protective measures that should be taken to ensure long-term durability?
I look forward to knowledgeable and practical feedback!
Hello Lado0,
First of all, respect for the detailed question! 🙂
KALLAX, as you probably know, is made from pressed wood fiber material (MDF), which is not exactly designed for extreme moisture resistance. With humidity levels as high as 70-80%, it can indeed happen that the material swells slightly over time or even the edges begin to soften.
However, I wouldn’t panic immediately if the shelf is placed somewhere where it isn’t constantly exposed to water. Good ventilation is important, and maybe applying a thin layer of clear varnish to especially vulnerable areas can help – this protects the surface and makes the wood a bit more resistant.
Oh, and if possible, using a dehumidifier or at least ventilating regularly can work wonders!
Hope this helps you for now :-)
Oh yes, KALLAX and humid air – that’s definitely a challenge!
I once lived in Southeast Asia, where the humidity is always above 75%. I used a similar shelf there; it stayed stable overall, but some corners warped slightly, and the paint started to peel.
My advice: look for a spray wax or a special wood preservative suitable for damp environments. Also, try not to place the shelf directly against exterior walls or windows, which tend to be cooler – that’s where moisture often condenses!
It’s great to know these tips – give it a try! 🙂
miAlessio6 Feb 2019 13:35Hello Lado0,
I would like to approach the question from a more technical perspective to clarify things:
1. Material: MDF (medium-density fiberboard), as used in KALLAX, is fundamentally wood-based and has a certain sensitivity to moisture depending on its density.
2. Moisture: a consistently high indoor humidity level of about 70-80% can cause capillary water absorption by the MDF, resulting in swelling and eventually deformation.
3. Protective measures: sealing with a water-repellent varnish (polyurethane or acrylic paint) can significantly reduce moisture absorption. However, this usually requires multiple coats.
4. Windows and exterior walls: avoid placing the unit directly against cooler exterior walls, as condensation tends to occur more frequently there.
Summary: The KALLAX shelf cannot tolerate consistently high humidity without protective measures. To prevent damage, sealing is recommended and good indoor ventilation is essential.
I also suggest regularly checking the shelf for any changes and taking action before significant damage occurs.
kaju67 schrieb:
"KALLAX is known to be made from pressed wood fiber material (MDF), which is not exactly designed for high moisture resistance."Thank you for the tip about using clear varnish – I have a question: Do you have a specific product recommendation for a varnish that works particularly well on MDF in tropical humidity?
I've often heard that some varnishes only provide a surface coating but are not truly water-repellent.
ixlu1 schrieb:
"... Look for a spray wax or a special wood preservative glaze suitable for damp environments."Would you recommend a varnish or a glaze product? Are there real differences in terms of durability under constant moisture exposure?
