ᐅ What is the best way to level Billy shelves on uneven floors?
Created on: 18 Aug 2023 19:23
reno56
reno56
18 Aug 2023 19:23
I’m currently facing the issue that my new Billy bookcase from IKEA doesn’t stand firmly on my uneven hardwood floor and wobbles slightly. I’m looking to find out how to properly level Billy shelves on uneven floors so they stand securely, don’t wobble, and remain stable over time. What practical methods or tools do you know to compensate for unevenness without the need for constant readjustment? It would be great if you could also share tips on tools or materials that have proven to be durable for this purpose.
I’ve already considered using furniture shims but am unsure if that’s the best solution—perhaps there are smarter or more professional options? Thanks in advance for your experiences and suggestions!
Tofra45
18 Aug 2023 20:04
The easiest solution is adjustable furniture feet or small wedges made of wood or plastic. These can be placed under the legs of shelves to individually adjust the height. Self-adhesive felt pads also help if there are only minor unevenness.
Jensson
18 Aug 2023 21:37
Hello Reno56,
I would like to offer you a somewhat more detailed approach to this topic that is often overlooked:
1. Check the floor carefully: First, use a spirit level to determine how uneven the floor is and exactly where the irregularities occur.
2. Position the shelf: Place the Billy shelf roughly in the desired spot.
3. Adjustable feet: IKEA sometimes offers suitable screw-in feet, or you can buy universal adjustable furniture feet from a hardware store. These can be adjusted individually to level the shelf precisely.
4. Permanent fixing: To prevent the feet from shifting during use, place rubber pads covered with lint underneath or use adhesive pads.
5. Alternatives: If adjustable feet are not an option, you can experiment with wooden shims or even silicone pads under the feet to fine-tune the height exactly.
Common mistake: Many try without precise measurement and then wonder why it still wobbles. Accuracy is important before fixing the position.
I hope this helps!
Katan
19 Aug 2023 07:49
Tofra45 schrieb:
The easiest are adjustable furniture feet or small wedges made of wood or plastic.
Absolutely right, and sometimes the small solutions can make a big difference! 🙂
I once leveled my Billy shelf using self-adhesive felt pads and a few unevenly cut wooden wedges from the hardware store. It was a great combination – discreet and stable. Plus, the wooden pieces give a charming "handmade" look if you don’t hide them completely.
If you fix the shelf to a wall (which is generally recommended anyway), small unevenness hardly ever causes tipping. So: find the balance, enjoy the process, and don’t be afraid to spend a few extra minutes on some DIY adjustments 😉
Good luck!
KUDAISY
19 Aug 2023 13:11
A structured approach can really help you. I’ll explain it step by step:
1. Identify uneven heights: Use a spirit level to find exactly where the floor height varies. Especially with parquet or old floorboards, there are often irregularities at certain points.
2. Check furniture feet: If your Billy bookshelf already has plastic or wooden feet, you can replace them with adjustable furniture pads available at hardware stores. These can be screwed or glued on and offer fine adjustment options.
3. Cut wedges: If you prefer not to use adjustable feet, cut wedges from hardwood or sturdy plastic and slide them under the bookshelf at the appropriate points. This method is affordable and durable.
4. Fixation: For extra stability, secure the wedges with double-sided tape or use small screws where possible. Most furniture should still remain movable.
5. Wall mounting: Always check if it’s possible to anchor the Billy bookshelf to the wall. Especially on uneven floors, wall mounting prevents tipping despite minor unevenness.
Additional tip: Avoid using soft materials as padding, as they may compress over time and the problem will reoccur.
This should allow you to quickly and permanently level your Billy bookshelves. Good luck!
