ᐅ Heat Pump Energy Consumption in 2019 on a Monthly Basis
Created on: 27 Nov 2019 10:44
Bookstar
I would like to start a new comparison thread and learn about your energy consumption. I am not completely satisfied with mine.
KFW55
Heated area 200 m2 (2,150 sq ft), underfloor heating
Standard rooms 19°C (66°F), living areas 22°C (72°F), bathroom 23°C (73°F)
Air-to-water heat pump with centralized controlled ventilation system
Domestic hot water temperature 50°C (122°F)
Data collection unfortunately only since April 2019:
April
407
May
347
June
109
July
131
August
144
September
198
October
356
I will update the table monthly. November will be included soon, with an estimated 650 kWh.
Bookstar
1 Dec 2019 19:01
That’s at least not a small amount. Hot water at 50 degrees Celsius (122°F) is fine, but reduce the hysteresis from 2K to at least 6K. I think the high consumption is more likely due to the flow temperature and the ERR.
Do you have a basement?
Lumpi_LE
1 Dec 2019 19:30
Sounds like a very high energy consumption at first for a KfW 40 house with 150sqm (1,615 sq ft). But it is located at a high altitude and the supply temperature is in the forest area.
Bookstar
6 Dec 2019 14:11
After my optimizations, my daily consumption has decreased from 60 kWh to about 30 kWh. However, I still find this too high. The goal would be 20 to 25 kWh at minus 3 degrees Celsius (27°F). That would be reasonable compared to others. At the moment, I’m not sure what else I can adjust.
Lumpi_LE
6 Dec 2019 14:25
20-25 is acceptable; if you use less with the same house, you might have large south-facing windows, lower indoor temperatures, slightly higher flow temperature, better insulation, less ventilation... and so on.
guckuck2
6 Dec 2019 14:58
I think 30 for the building size is not entirely unrealistic. It also varies from day to day.
What settings have you settled on now?
Lumpi_LE
6 Dec 2019 15:16
Oh, I see, "the goal would be," sorry, misread that.
