I would like to start a new comparison thread and learn about your energy consumption. I am not completely satisfied with mine.
KFW55
Heated area 200 m2 (2,150 sq ft), underfloor heating
Standard rooms 19°C (66°F), living areas 22°C (72°F), bathroom 23°C (73°F)
Air-to-water heat pump with centralized controlled ventilation system
Domestic hot water temperature 50°C (122°F)
Data collection unfortunately only since April 2019:
I will update the table monthly. November will be included soon, with an estimated 650 kWh.
KFW55
| April | 407 |
| May | 347 |
| June | 109 |
| July | 131 |
| August | 144 |
| September | 198 |
| October | 356 |
Lumpi_LE schrieb:
13500 is, of course, a significant figure, but not entirely unrealistic.
If the house hasn’t had any energy-efficient renovations, 200 kWh/m²*a (200 kWh/m²*a) is a realistic value. That results in 200 kWh/m²*a × 200 m² (2150 ft²) × 1 year = 40,000 kWh. Annual performance factor = 40,000 / 13,500 = 3.0 — which is also not unrealistic for an uninsulated older building. The consumption energy certificate shows a final energy consumption of 51 kWh/m²*a (51 kWh/m²*a), but it also lists this approximate annual consumption of 13,000 kWh over recent years.
Tobibi schrieb:
51 kWh/m2aYes, that only refers to the electricity consumption of the heat pump.Lumpi_LE schrieb:
Yes, that only refers to the electricity consumption of the heat pump.Sorry for the silly question, but what else is included to reach the 200 kWh/m2a mentioned earlier?Hello everyone, I think the idea of a comparison is actually quite good. If as many people as possible provide their details as accurately as possible here, eventually we will find a comparable house with similar conditions. In our case (2 people, always at home) it looks like this:
KFW supposedly 40, building is at 720 m (2,362 ft) above sea level
heated area 150 m2 (1,615 sq ft), underfloor heating
all rooms at 22 °C (72 °F)
air-to-water heat pump with decentralized controlled residential ventilation
domestic hot water temperature 50 °C (122 °F) from October to March, otherwise set to 65 °C (149 °F) to optimize photovoltaic use, wood stove heated 8 days a year.
The figures show the total consumption of the heat pump including electric heating element and cooling in June, July, and August (with photovoltaics). Moved in autumn 2018.
November 392
| April | 291 |
| May | 226 |
| June | 202 |
| July | 205 |
| August | 192 |
| September | 184 |
| October | 136 |
November 392
