ᐅ Heat Pump Energy Consumption in 2019 on a Monthly Basis
Created on: 27 Nov 2019 10:44
Bookstar
I would like to start a new comparison thread and learn about your energy consumption. I am not completely satisfied with mine.
KFW55
Heated area 200 m2 (2,150 sq ft), underfloor heating
Standard rooms 19°C (66°F), living areas 22°C (72°F), bathroom 23°C (73°F)
Air-to-water heat pump with centralized controlled ventilation system
Domestic hot water temperature 50°C (122°F)
Data collection unfortunately only since April 2019:
April
407
May
347
June
109
July
131
August
144
September
198
October
356
I will update the table monthly. November will be included soon, with an estimated 650 kWh.
truce3 Feb 2020 22:20
Bookstar schrieb:
[...] about 30 years payback period compared to air-to-water heat pump [...] That’s why brine systems remain something for enthusiasts [...]
I can’t leave it at that.
The quotes we received from the heating contractor were:
  • Air-to-water heat pump around 9,000 € (including installation)
  • Brine-to-water heat pump around 12,000 € (including installation)
Ground heat installation, done by ourselves, around 3,000 € total
BAFA subsidy 4,500 €
This leaves a net difference of 1,500 €.
We will recover that within a few years and additionally do “something” good for the environment.
guckuck2
3 Feb 2020 22:22
@truce
Have you determined the annual performance factor?
How was the heat source identified for the modulating heat pump, and did it cause any issues with the parties involved?
What is the size of the domestic hot water storage tank?
tomtom793 Feb 2020 22:45
Wow, those are some prices that will make my wallet jealous.
truce3 Feb 2020 23:04
guckuck2 schrieb:
@truce
1. Have you determined the annual performance factor (APF)?
2. How was the heat source for the modulating heat pump determined, and did it cause any issues with the parties involved?
3. Size of the domestic hot water tank?
1. Yes, but due to the relatively higher share of domestic hot water production compared to less insulated houses, the annual performance factor is just below 5 (currently 4.86).
2. The source was designed based on the heating load determined before construction (approximately 6–7 kW). In hindsight, the source could have been slightly larger. Currently, the brine inlet and outlet temperatures are 4.2°C (39.6°F) and -0.4°C (31.3°F).
3. 190 liters (50 gallons) and no additional buffer tank (with good photovoltaic feed-in, 1–2 K [1.8–3.6°F] more heat is stored in the screed, causing slight overheating).
Bookstar
4 Feb 2020 06:30
Oh, I thought you meant drilling! Well, then that's great.
