ᐅ Heat Pump Energy Consumption in 2019 on a Monthly Basis
Created on: 27 Nov 2019 10:44
Bookstar
I would like to start a new comparison thread and learn about your energy consumption. I am not completely satisfied with mine.
KFW55
Heated area 200 m2 (2,150 sq ft), underfloor heating
Standard rooms 19°C (66°F), living areas 22°C (72°F), bathroom 23°C (73°F)
Air-to-water heat pump with centralized controlled ventilation system
Domestic hot water temperature 50°C (122°F)
Data collection unfortunately only since April 2019:
April
407
May
347
June
109
July
131
August
144
September
198
October
356
I will update the table monthly. November will be included soon, with an estimated 650 kWh.
michert
27 Nov 2019 19:17
guckuck2 schrieb:
It is especially inefficient to want to keep small rooms very warm, which requires the supply temperature to be set high, while the other rooms are throttled by the temperature control valve because they are supposed to stay cooler. This makes the heat pump less efficient due to the higher supply temperature, and the circulation pump works against closed valves. Not ideal.
It’s definitely better to run a portable heater in the bathroom for 10 minutes a day than to increase the supply temperature and force the heat pump to short cycle.
Bookstar
27 Nov 2019 19:38
How often is cycling considered good or normal?
I was able to reduce the hot water cycling from 7 times daily to just once.
For heating, the system still cycles about 13 times daily between 27°C (81°F) and 31°C (88°F).
boxandroof
27 Nov 2019 19:43
As little as possible. There is no such thing as "normal." It cycles infrequently if there is sufficient flow, if it is not oversized, and/or if it can modulate deeply. A buffer tank in the heating circuit would also not be ideal.
Bookstar
29 Nov 2019 08:12
Currently, I am facing the same issue as before my optimization, with very low flow rates throughout. Upstairs, I can’t even reach one liter, although all valves on the manifold are fully open. On the ground floor, it’s 1.5 liters. Naturally, the rooms upstairs are cooling down as a result, with the bathroom only at 21.5°C (70.7°F).
I don’t know what could be causing this. As a layperson, I would suspect the pump. Does anyone have any advice?
Lumpi_LE
29 Nov 2019 08:41
The pump usually has adjustable settings. But basically, 1.5 L is not bad per se; in the end, the differential pressure needs to be correct.
halmi
29 Nov 2019 08:41
What settings are configured for the pump control?
