ᐅ Floor plan design for a single-family house, 165 sqm, without a basement, on a 400 sqm plot
Created on: 10 Aug 2023 09:33
Maulwurfbau
At the request of 11ant, here is a post with the completed list ;-) Unfortunately, he still doesn’t have a crystal ball.
Providing all information possible/available at this point in time.
Plot size: 400 sqm (4300 sq ft)
Slope: No, and no means no!
Floor space index (FSI): 0.4
Floor area ratio (FAR): ?
Building envelope, building line and boundary: Yes, available.
Edge development: Possible with garage.
Number of parking spaces: at least 1, preferably 2
Number of storeys: 1-2
Roof type: Gable roof (pitch minimum 31°, maximum 45°)
Architectural style: ??
Orientation: Gable end facing
Maximum heights / limits: Roof ridge 6-7 m (20-23 ft), eaves 9-12 m (30-39 ft)
Other requirements: No brick facades allowed. Driveway or space in front of garage at least 6 m (20 ft). Red roof tiles mandatory, light facade.
Homeowners’ Requirements
Architectural style, roof type, building type: Gable roof, fixed
Basement, storeys: 2 full storeys without basement
Number of occupants, age: 4 people (2 toddlers)
Space requirements on ground floor and upper floor:
Office: Family use or home office? Office of approx. 12 sqm (130 sq ft) is a must.
Guest bedrooms per year: Few
Open or closed architecture: ? Whatever that means.
Conservative or modern construction style: rather modern construction.
Open kitchen, cooking island: Open kitchen, possibly with cooking island
Number of dining seats: 6
Fireplace: NO
Music / stereo wall: Not planned, TV location is quite important.
Balcony, roof terrace: NO
Garage, carport: Garage desired. Carport with storage box also conceivable.
Utility garden, greenhouse: NO
Further wishes / special features / daily routine, preferably with reasons for choices:
Laundry room on the upper floor. They want to do laundry where it is generated and where it must be returned clean. Anything else is a hassle, at least for us.
Who designed the plan: Architect
Everything we provided as basic information and what our daily life requires has been implemented.
We like the clear lines/structure.
The open space in the hallway.
The connection/proximity of all rooms on ground and upper floors that need water/sewage. So no funny business with the bathroom upstairs in one corner and the utility room diagonally opposite on the ground floor. Personally, I like that.
No bay windows or other awkward extensions.
Laundry room upstairs where the washer and dryer are planned.
What don’t you like? Why?
The living room might be a bit too exposed for us. It could also be a cozy nook with TV without direct view of the kitchen. Cooking and eating together openly is liked; the living room could be a bit more separate. Currently, the floor plan shows it like a narrow, rather shadowy corner.
The somewhat narrow bedroom upstairs is not a dealbreaker but not 100% pleasing.
Personal price limit for the house, including fixtures and fittings:
500-575k
Preferred heating system:
Predefined, ground source heat pump with collector. Cold local heating network.
If you have to give up, which details/extras
-can you do without:
The small additional room for the father upstairs.
Garage, as mentioned carport also conceivable.
-can you not do without:
Office.
Storage box at garage or carport.
Children’s rooms.
The design turned out this way because the architect implemented our wishes and requirements almost 1:1. This preliminary layout resulted in this first version.
What do you consider particularly good or bad?
See what we like and what not. We don’t find anything particularly bad. Rather, not entirely optimal.
Position garage flush with house or set back?
43.5 sqm (468 sq ft) + 4 sqm (43 sq ft) pantry sufficient as “all-purpose room”?
Same floor plan possibly mirrored? Then office on south side, sun all day, blinds always down. Same issue upstairs with bedroom in summer at least. Entrance farther from parking space.
The building method will be timber frame construction with a local timber builder.
This is a first sketch after clarifying needs/wishes with the architect.
Floor plan of a house with living, dining, kitchen, office, hallway, terrace, and garage.
Floor plan of a storey with hallway, bedroom, children’s room, dressing room, bathroom.
Site plan of house with red property boundary, building footprint, north arrow, street names.
kbt09
10 Aug 2023 15:08
Should it be two full stories? If not, then consider the sloping roof in the upper floor.
Otherwise... phew... living, dining, and kitchen areas within 915cm (9.15 meters / 30 feet) of exterior width don’t leave much space. In general, dimensions are missing.
However, the staircase seems to be planned with sufficient length 😉
11ant10 Aug 2023 15:10
One hardly dares to hope that the HAR here is more than just a placeholder, but actually filled with the realistic clutter (including restricted areas).
I meant "calculated," since nothing is actually marked here.
Maulwurfbau
10 Aug 2023 16:20
kbt09 schrieb:
Otherwise ... phew ... Living, dining, and kitchen areas within 915 cm (30 feet) of external width don’t leave much space. Generally, dimensions are missing.
Yes, we also find it "just" okay, but without enthusiasm. Rather a bit tight.
There will be 2 full stories.
10 Aug 2023 18:26
How wide is the sofa niche? And how far is it from the TV? It seems to me that you are already sitting in the lounge area while at the dining table. So the broom closet will just be a nicely disguised storage niche?
A bedroom used as a walk-through room is usually a constant source of conflict for partners…
I like the bathroom.
Aspirant
10 Aug 2023 19:20
Not least, single-run straight staircases are literally a "pain in the neck."
Is that really the case everywhere? Our planning is currently based on the floor plan of the Baufritz house "Schneider," just a bit larger and with a bathroom reduced upstairs. It is precisely the staircase that creates the cozy feeling of a "living nook." Of course, this is not the case in that floor plan.
Maulwurfbau
10 Aug 2023 19:25
How wide is the sofa niche? And how far is it from the TV? It seems like you’re already sitting in the chill area when at the dining table. So the Büronie niche is just a nicely spun useless niche?
A bedroom used as a passage room is almost always a deal-breaker for partners…
The sofa niche is just over 3 meters (about 10 feet).
Yes, I know the phrasing. What helps one person is nonsense to another. So, whatever.
Fake thread? The bedroom is not a passage room. That wouldn’t suit us either.
