ᐅ Setting Up Shelving Units in Rooms with Sloped Ceilings – How to Adapt Them?
Created on: 4 May 2015 17:22
KAU40
KAU40
4 May 2015 17:22
Hello everyone, I’m facing the challenge of fitting a Billy bookshelf in a room with a sloped ceiling and I’m wondering how to best adapt it to make optimal use of the storage space without compromising the shelf's appearance or functionality. Are there any proven methods to adjust the Billy bookshelf to a slanted wall, for example by cutting or additions? Or perhaps alternative mounting options? I would appreciate practical tips or experiences specifically related to rooms with sloped ceilings. Thanks in advance!
JONKO
4 May 2015 17:48
Hello KAU40, I can definitely understand how tricky this can be – sloped ceilings don’t make things any easier.
KAU40 schrieb:
I’m facing the challenge of setting up a Billy bookcase in a room with a sloped ceiling and wondering how best to adapt it to make the most efficient use of storage space
I’ve tried redesigning a room myself, and it’s very helpful to first take precise measurements of the room and then see if the bookcase can be shortened or if you can install an open shelving unit along the sloped wall only up to a certain point.
Have you considered combining the Billy bookcase under the slope with additional cabinets or shelves? This way, you avoid wasting the limited space. Sometimes it helps to think creatively and see the room as a combination of different furniture pieces rather than just one bookshelf.
I’d be interested to know the height of your sloped ceiling and how deep the slope actually is.
Garth49
4 May 2015 18:15
JONKO schrieb:
I have tried redesigning a room myself, and it’s very helpful to first measure the space precisely
That’s brilliant! You really have to approach it with enthusiasm, then it becomes a lot of fun 🙂
I once had my Billy bookcases in a room with a pitched roof and simply adjusted the upper shelves to follow the slope, even though this meant the shelves were no longer perfectly straight.
By the way, you can also use angle brackets or small extra shelves to make the most of the space under the slope. Tip: Just experiment creatively with different variations. Good luck!
lis64
4 May 2015 18:46
You can shorten the bottom of Billy shelves and install a matching trim board along the slope. If desired, it can also be secured to the wall for added stability.
FAZAR
4 May 2015 19:23
Basically, there are different approaches to optimally adjust a Billy bookshelf in a room with a sloped ceiling.
First: Precisely measuring the height at various points along the slope is essential. Only then can you plan whether cutting the side panels or shelves makes sense.
Usually, it is advisable to cut the back panel on the sloped side or replace it with a board that fits the angle. You should know that the bookshelf itself is made of particleboard, which makes cutting easier.
Technically, I would suggest:
1. Measure the angle’s length and height using a protractor
2. Mark the bookshelf frame along the slope from below to ensure an exact cutting line
3. Adjust the side panels, back panel, or shelves accordingly
4. Secure the unit to the wall, as stability may be affected by the modifications
Also, you should keep in mind that the load capacity at the cut areas might be reduced. Therefore, always work with appropriate tools and sand the cut edges to avoid damage.
What does the room look like exactly? Do you perhaps already have a sketch or precise measurements? That would help a lot in providing a detailed recommendation.
sonrickey
4 May 2015 19:51
FAZAR schrieb:
Customize furniture, consider technology, ensure safety
I think you described it very professionally, I agree with that! 🙂
I would also suggest not overdoing the idea with the original Billy shelf—sometimes less is more. You might also consider positioning the shelf so that it only touches the sloped ceiling at the highest corner and keeping the shelves relatively low.
Additionally, a few decorative elements at the opening to the slope can make a big difference, such as colorful boxes or plants. This creates a nice atmosphere and helps divert attention from the awkward slope somewhat.
Have fun setting it up! 🙂
