ᐅ Footrest for shaving legs in the shower
Created on: 22 Aug 2023 21:37
mr.xyz1
Hello everyone, my wife would like a footrest to make it easier to shave her legs.
Who has a built-in solution and would like to share it? Or an alternative solution? So far, I have also seen supports for corners at the major online stores. Does anyone have a recommendation for a specific product?
23 Aug 2023 18:20
mr.xyz1 schrieb:
Correct, I asked about the shower. A bathtub edge would be impractical since the shower is not used inside the bathtub.
Yes, but also looking for a simple solution. And this would be it.
motorradsilke
23 Aug 2023 19:55
Would that really be a simple solution if you have to climb into the bathtub to shave after showering?
HeimatBauer
24 Aug 2023 07:56
In the bathroom, we have a built-in shower wall with a shampoo niche. We seriously considered adding a second niche at the bottom for shaving, like in the picture. I wouldn’t want to miss the existing niche.
If I were to build again, I would include a slightly sloped (just enough for water to drain) seating area. At the right height, it can be used both as a footrest and as a seat for "showering together" or any other positions you might think of. A sturdy grab bar in the shower isn’t just for seniors; even young couples sometimes appreciate having something stable to hold onto while showering.
mr.xyz1
24 Aug 2023 08:17
Schorsch_baut schrieb:
We will proceed with it this way. This option saves the most space and allows us to use the “accent tile” from the shampoo area again. Thanks for your input.
DeepRed24 Aug 2023 09:38
HeimatBauer schrieb:
(...) even young couples sometimes spontaneously appreciate such grab bars in the shower.
It's just a pity that my wife has a much higher tolerance for shower water temperature than I do. Otherwise... made my day! 😎
Fuchsbau35
24 Aug 2023 17:35
DeepRed schrieb:
Too bad my wife’s shower water temperature differs greatly from mine. Otherwise... made my day! 😎
If the shower is large enough, you can install two separate shower heads with individual controls. I’ve seen that done as well. Then each person can set their own temperature 😉
