ᐅ Single-family house floor plan, approximately 150-160 sqm on a 480 sqm plot in Middle Franconia
Created on: 18 Mar 2022 00:49
RufusJWB
Hello!
Here are our initial thoughts regarding our single-family home. I would greatly appreciate your comments (including critical ones). I will try to answer all questions promptly.
Plot size: 481 sqm (5180 sq ft)
Slope: none
Building coverage ratio: 0.4
Floor area ratio: none
Building window, building line, and boundary: approx. 19 m (62 ft) (north-south) x 24 m (79 ft) (east-west), see cadastral map
Edge development: only carport / garage
Number of floors: 2 + pitched roof
Roof shape: pitched, flat, shed
Design style: none specified
Orientation: none specified
Maximum heights / limits: gable 9 m (30 ft), eaves 6.5 m (21 ft)
Other requirements: none
Design style, roof shape, building type: modern / Franconian, pitched or shed roof
Basement, floors: yes, ground floor + upper floor
Number of occupants, ages: 4 persons, 2 adults, 2 children aged 1 and 4
Space requirements on ground and upper floors: see room program
Office: family use or home office? Home office & music room (for music teacher) (see room program)
Number of overnight guests per year: typically 1-2, up to 4
Number of dining seats: 4 (6)
Fireplace: preferably yes, possibly as pellet stove in the living room
Music / stereo wall: not necessary
Garage, carport: carport in front of the house
Other wishes / special features / daily routine, also reasons why some things should or should not be included: The music room should become part of the living room when not used for teaching, as the piano is located there.
Who created the design:
- Architect: many inspirations from picture books
- Do-it-yourself: and then supplemented by us according to our needs
What do you particularly like? Why? The open and transparent architecture on the ground floor, the clear southern orientation
What do you not like? Why? Perhaps it is a bit too small, so we might make it one meter longer. We can only fit the home office & guest room in the basement.
Price estimate according to architect/planner: We told the construction company a limit of 500,000 € for the house, and so far there has been no rejection. We do not have any firm offers yet.
Personal price limit for the house, including equipment: 550,000 € + carport + utility connections + etc. → max. 700,000 €
Preferred heating system: pellet stove or heat pump
--> Perhaps a quarter-turn staircase would be better, as it would provide additional space for the music room on the ground floor and allow the play area upstairs to be separated from the staircase by a railing.
--> The basement is still not fully planned.
If you have to give up any details / expansions:
- you can do without: the design is already very simple; if necessary, the guest bathroom in the basement and the kitchen island. An L-shaped kitchen would probably also work.
- you cannot do without: the music room and the WC on the ground floor.
Why has the design turned out the way it is? For example:
Which wishes from the architect have been implemented? --> The construction company’s planners have difficulty implementing our ideas.
A mix of many examples from various magazines? --> Yes
What do you consider particularly good or bad about it? --> The open architecture on the ground floor and the (almost) equally sized rooms upstairs.
What is your constructive critical opinion of our design? What would you do differently?
Room program:
Ground floor
Kitchen
Dining room (ideally with direct access to the kitchen)
Living room (with seamless transition to the dining room)
Music room (with a large sliding door to the living room; when open, it becomes part of the living room; direct access from hallway)
Hallway
Guest / student toilet
Basement
Utility / technical room
Storage / laundry room
Guest room
Guest bathroom
Home office
Upper floor
Children’s rooms 1 & 2
Master bedroom
Family bathroom
Outdoor spaces
Carport
Garden shed / storage shed
Waste container shelter
Floor plan of a house: kitchen with island, living room, hallway, bathroom, WC, staircase on the right.
Site plan of a plot with red marking at the bottom of the image; continuation certificate 809 03 Heßdorf.
Hand-drawn floor plan of the attic with bathroom, hallway, and rooms.
gutentag24 Mar 2022 11:50
The height indication in point 2.5 is unclear. What is considered the surrounding wall? Which handrail height is meant? The existing one or the final one?
gutentag24 Mar 2022 12:09
I would start by planning the outdoor area first in order to determine the reference point for the ground floor raw slab height.
Daylight in the basement will then be difficult, unless you integrate light wells into the perimeter wall.
In my opinion, a basement is not an option here anyway due to the lack of budget.
Is there already a quote from the prefab house supplier? Does it include the basement or just the foundation slab?
RufusJWB
24 Mar 2022 15:38
gutentag schrieb:
The height specification in point 2.5 is unclear. What is considered the perimeter wall? Which railing height is meant? The existing one or the final one?
Good question. I would need to clarify this with the local authority.
RufusJWB
24 Mar 2022 15:41
gutentag schrieb:
I would first plan the exterior landscaping to determine the reference point for the ground floor unfinished floor height.
Daylight in the basement will be difficult unless light wells are integrated into the retaining wall.
We have considered light wells.
gutentag schrieb:
In my opinion, a basement is not feasible here due to the limited budget.
We still have some budget buffer (at least as long as interest rates don’t rise sharply) for the basement.
gutentag schrieb:
Is there already an offer from the prefabricated house provider? Does it include the basement or the concrete slab?
Not yet. The first offers should arrive within the next few days. If necessary, that might give us a good reason to reduce the size of the house.
11ant24 Mar 2022 16:01
RufusJWB schrieb:
We still have a bit of budget flexibility (at least if interest rates don’t rise sharply) for the basement.
versus
RufusJWB schrieb:
Not yet. The first ones are expected to arrive in the next few days. If necessary, this might give us a good reason to reduce the size of the house.
That’s for whoever wants to understand *head scratch*
RufusJWB
24 Mar 2022 16:16
versus
I don’t understand that *scratches head*
I’m afraid that the costs for the house my wife and I have currently planned according to our wishes will exceed the base budget plus contingency. However, I really can’t estimate by how much. Therefore, I am now waiting for quotes from construction companies in order to know how much we will need to cut back – and perhaps also to receive suggestions from them about the main cost drivers so that we can address these more effectively.
