lexhevdet16 Sep 2018 19:37Hello everyone, I am currently considering the idea of extending or widening the shelves of my Ikea Kallax unit, as I need a larger surface area. My goal is to modify the existing shelves so that the new surface remains stable and load-bearing without having to buy a completely new unit. My questions: Are there any proven methods or DIY solutions for safely extending Kallax shelves? Which materials and fastening techniques provide the necessary stability? Are there any tips for cutting or finishing the surfaces to ensure everything fits and looks good? Thanks in advance for any helpful advice or shared experiences!
Basically, extending Kallax shelves is possible if the following points are considered: Kallax shelves are usually made of particleboard with a melamine coating, which is not very strong over a longer span, so the extension must be supported as well as possible. A common method is to attach an additional support made of wood or metal under the extended boards to prevent sagging. For this, a sturdy bracket or MDF board can be used as reinforcement, mounted to the underside of the entire shelf surface. Accurate measurement and cutting of the extension parts are important to ensure a proper fit. Alternatively, you can use a similar shelf board in the correct width (e.g., from a hardware store), finished with paint or coating to match, and fix it under the original shelves with screws or brackets. Be sure to pre-drill to avoid damaging the material. Surface finishing can be done with melamine adhesive sheets or self-adhesive film from a hardware store if you don’t have genuine melamine coating. It is essential to prevent any moisture from seeping in, as this will cause the particleboard to swell.
To extend the Kallax shelves, I recommend a clear approach to ensure stability and appearance:
1. Take exact measurements: length, width, and thickness of the existing board.
2. Material choice: Use a particleboard or MDF panel of the same thickness for the extension. These are often available pre-cut at hardware stores.
3. Reinforcement: Screw a wide wooden batten (solid wood or plywood) underneath the joint to distribute the load and prevent the extension from bending.
4. Connection: Use concealed screw joints or specialized wood connectors (such as Domino or flat biscuits) to keep the surface clean.
5. Surface finish: Melamine foil or a white adhesive film from the hardware store provides a neat finish. Be sure to seal the edges with clear varnish or edge banding to protect against moisture.
6. Installation: Prop the work surface horizontally and carefully fit the parts together.
Common mistakes: Using supports that are too weak, not creating a proper joint, risk of breakage at the connection.
With this method, you will achieve a clean, stable, and visually matching extension. 🙂 If you like, I can provide more detailed tips on the tools.
keole schrieb:
Build a wooden batten underneath the extension to serve as a support. That works perfectly, that’s exactly how I did my self-made Kallax upgrade. I simply used a wooden batten, it holds really well and even looks quite neat.
BEMAU schrieb:
It’s important to measure precisely and cut the extension parts accurately so the fit is perfect. Exactly! Nothing is worse than wobbly edges or uneven surfaces.
A quick tip: If you want the new surface to have a bit more grip, you can lightly sand the top after applying the foil for better slip resistance. That really helped me when stacking folders 😉 Once everything is firmly in place, your bookshelf’s “dashboard” will look great too. Good luck!
