here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Cost: €9,800
annab377 schrieb:
So, in summer—without much time pressure—do you run the screed heating program with the brine-to-water heat pump? Okay, thanks 🙂 For the screed heating program, a buffer tank or hot water storage tank isn’t necessary, right? So you can operate this just with the underfloor heating pipes and the brine-to-water heat pump? 🙂
annab377 schrieb:
For the screed heating program, a buffer tank or domestic hot water storage is not necessary, right? So it can be operated only with the underfloor heating pipes and the brine-water heat pump? 🙂Either the heating element or an external heater is used for this, rarely the brine source. Because it could be overloaded to the point of irreversible damage.
nordanney12 Apr 2021 15:06guckuck2 schrieb:
Either the heating element or an external heater is used for this, rarely the brine source. The brine source could become overloaded, leading to irreversible damage. Since it is now reasonable to heat only up to 35 degrees Celsius (95°F) anyway (yes, I know, the official heating tables from the screed manufacturer usually allow up to 55 degrees Celsius (131°F) – but that is due to the old heating technology with oil/gas), you can easily run a heating program with a brine-water heat pump (or air-water heat pump).
