ᐅ Experiences with Anti-Mold Sprays for Indoor Use from KALLAX?
Created on: 8 Dec 2022 13:47
niatillaHello everyone, I have a specific topic where I’m really hoping for your experience: It’s about anti-mold sprays designed specifically for indoor use on IKEA KALLAX shelves. I often use these shelves in rather humid rooms like the bathroom and have unfortunately occasionally noticed small signs of mold, which bothers me because the cube storage units are open and delicate. I am particularly interested in how effective these anti-mold sprays are, whether they leave harmful residues (especially when used on open shelf compartments), and if the surfaces of the KALLAX remain truly undamaged after treatment. If anyone has longer-term experience with a particular product or tips on proper application (either as a preventive measure or for active mold issues), please share. Thank you very much in advance!
Alberto518 Dec 2022 14:32Hello niatilla, this is truly an important topic that affects many of us, especially in rooms with a bit more humidity.
I can really relate to that – mold is simply frustrating and a health hazard. A few months ago, I also tried an inexpensive anti-mold spray on my KALLAX, which is often recommended in hardware stores. The effect was noticeable for me, the mold was clearly reduced, but the problem was unfortunately not completely eliminated. In addition, I experienced a slight chemical sensation during application, which made me a bit unsure whether it is safe for the living environment in the long term.
As you already mentioned, it does no good if the surface gets damaged, especially with wooden furniture. I also made sure to ventilate very well after treatment to reduce residues.
I would like to know if anyone is aware of something more natural or longer lasting that still works. Best regards and thanks for preparing this topic so thoroughly!
niatilla schrieb:
I often use these shelves in rather damp rooms like the bathroom and unfortunately have occasionally noticed small signs of mold
PeoDaniel8 Dec 2022 15:03Hello niatilla and everyone else, I would like to elaborate a bit on this topic because dealing with mold on furniture often leads to misunderstandings.
First: With anti-mold sprays, it is important to distinguish whether they only kill the visible mold or also prevent the spores from growing back.
Many products contain active ingredients like azoles or chlorine compounds that are effective but can release potentially harmful gases in poorly ventilated areas. Therefore, experts recommend applying the treatment in well-ventilated rooms and letting the furniture air out for several hours afterward.
Second, regarding surfaces: KALLAX shelves are often made of particleboard with a foil coating. Some aggressive agents can damage this coating and make the furniture more vulnerable. For this reason, products specifically designed for wood or furniture should be preferred.
Third, the best protection is preventive: regular ventilation, using a dehumidifier, and avoiding placing furniture directly against exterior walls if there are often moisture problems there.
If mold spots are already visible, they should be thoroughly removed before applying the spray (using gloves and a protective mask), otherwise the spray will only be partially effective.
I hope this helps. I am also interested to hear about what products other users have tested here.
niatilla schrieb:
whether they leave harmful residues (especially when used on open shelves)
A brief addition: I recommend thoroughly cleaning and drying the piece of furniture before treatment. Then, spray the anti-mold spray evenly from about 20 cm (8 inches) away, allow it to dry properly, and ventilate regularly afterwards. Most sprays provide protection for up to 6 months. After that, the treatment can be repeated.
Alberto519 Dec 2022 10:13PeoDaniel schrieb:
Products specifically designated for wood or furniture are preferredThat’s true, which is exactly why I avoided using much stronger agents.
Repar schrieb:
Ventilate regularly. Most sprays protect for a maximum of 6 monthsFor me, that’s the most important insight. Fighting mold is not a one-time task but an ongoing process. I also wanted to mention that sometimes I feel overwhelmed by the treatment because I’m not sure if I’m doing too little or too much.
Does anyone have experience with differences in effectiveness between products containing biocides and those with purely natural ingredients? Sometimes I feel that the natural remedies are too weak.
flo-Theres10 Dec 2022 09:44Hello everyone, I would like to summarize a few important points from my perspective that also relate to your questions:
1. Effectiveness: Chemical anti-mold sprays can be effective but should be used with caution. For wooden furniture like KALLAX, it is important that no aggressive solvents are included that could damage the surface.
2. Natural Alternatives: Vinegar or tea tree oil have some antimicrobial properties but usually only work temporarily and often not against all types of mold. However, they are worth considering for indoor use with sensitive furniture.
3. Prevention: Reducing indoor humidity and regular cleaning (using dry cloths, avoiding dusty surfaces) lowers the risk of mold.
4. Application: After treatment with anti-mold spray, ensure good ventilation. Immediately wipe off any spray droplets on other surfaces to prevent damage.
5. Long-term Protection: There are now water-based mold-resistant impregnations suitable for wood that do not contain harsh chemicals.
Anyone with a severe mold problem should also address the cause of indoor humidity, as no spray will help permanently otherwise. I hope this information is helpful!
