ᐅ Drain Outlet for Raised Washing Machine Too Low – Possible Solutions?
Created on: 15 Jun 2024 15:18
BoPaDi24
BoPaDi24
15 Jun 2024 15:18
We would like to install our washing machine elevated by about 60 cm (24 inches). However, the wastewater connection is only about 80 cm (31 inches) above the finished floor level. According to the washing machine’s manual, the drain should be between 60 and 100 cm (24 and 39 inches) high. If the washing machine is raised by 60 cm (24 inches), the drain would, in my understanding, need to be at least 120 cm (47 inches) high.
How could this be solved? Opening the wall to raise the drain is not really a practical option. There must be other possibilities, right? We would appreciate any tips.
nordanney
15 Jun 2024 15:33
BoPaDi24 schrieb:
There must be other options, right?
Just install the connection surface-mounted a bit higher – simply use PVC pipe. Insert an elbow, fix a straight pipe going upward to the wall with a clamp, and then place the washing machine wastewater connection at the top.
Harakiri
15 Jun 2024 15:34
If your washing machine drum is actually positioned above the drain, then creating a 180-degree loop with the flexible drain hose is sufficient. There are also wall brackets available to keep it stable.
Tolentino16 Jun 2024 12:44
Can someone explain the problem to me? I understand that the drain should not be too high, but what would be the issue if it is "too" low?
hanghaus2023
16 Jun 2024 13:05
Tolentino schrieb:
Can someone explain the problem to me? I understand that the drain shouldn’t be too high, but what would be the issue if it’s "too" low?
Then the water might drain unintentionally.
BoPaDi24
16 Jun 2024 14:47
nordanney schrieb:
Just raise the connection surface-mounted a bit higher – simply using a PVC waste pipe. Insert an elbow, fix a straight pipe upwards to the wall with a clamp, and then connect the washing machine drain at the top.
I initially thought about just attaching a trap and then connecting the wastewater at the top of the trap. However, I would lose nearly 10cm (4 inches) in depth, and I want to keep the cabinet as close to the wall as possible since our utility room is generally very narrow. I’m afraid the loss with a PVC bend would be even greater, right?
Harakiri schrieb:
If your washing machine drum is indeed above the drain level, it’s enough to create a 180-degree loop with the flexible drain hose. There are also wall brackets for this to keep it stable.
The drain is roughly at the height of the beginning of the washing machine drum. Creating a loop would of course be the easiest solution. Thanks for the tip!
