ᐅ Is it possible to have a floor drain and a separate water line?
Created on: 5 Feb 2021 11:35
Hausbau12
We are currently planning our house and kitchen.
We have two cats for whom we installed a "drinking fountain" right next to the sink in the guest bathroom. It has an infrared sensor and a separate connection to the water supply line beneath the sink. So far, it works well.
In the future, I would like the water for the cats to be in the kitchen, so we are not dependent on the guest bathroom door being open. However, I don’t want it at the kitchen sink, as the cats would then be on my kitchen countertop.
Ideally, I would prefer the whole setup to be on the floor.
My idea is now to have a separate water connection (similar to the one we have for the refrigerator ice maker) and a drain in the floor.
Would something like this be possible? Anyone have any ideas?
White cylinder with lid and long transparent tube next to the bathroom sink.
Hausbau12
6 Feb 2021 00:33
There will be no utility room. I would prefer the kitchen.
Currently, the drinking fountain is connected to the water supply below the washbasin using a T-piece.
O
Olli-Ka
6 Feb 2021 06:55
strange thing...
What happens if it doesn’t shut off the water?
Or if the cat plays around with it...
Does the whole kitchen or whatever else flood?
I would have issues with firmly connecting any device to the water line without a proper drain.
Regards, Olli
Hausbau12
6 Feb 2021 08:31
The water currently just drains directly in the sink. My question is whether it is possible to install a floor drain in the kitchen?
hampshire
6 Feb 2021 09:38
Of course, you can install a floor drain. The effort depends on the floor construction. Technically, it’s not a problem, but the costs can be quite high, especially if you have to work around underfloor heating, for example. Sometimes, a wall drain and a small platform might be sufficient.
I suspect that a renovation would be more expensive than simply leaving the guest toilet door open or installing a cat flap there.
O
Olli-Ka
7 Feb 2021 03:33
We used to have a cat as well.
It just had two bowls, one for cat food and one for water.
You just had to refill them regularly.
I also think that installing a floor drain in the kitchen afterwards is quite a bit of work.
Especially since the entire kitchen floor under the screed actually needs to be insulated.
Olli
Hausbau12
7 Feb 2021 08:57
You only need to justify or explain things that were already mentioned in the original post...
It's great for you and your cats that you were happy with bowls. Cats love running water. I love my cats. It's that simple. What an unfriendly and unnecessary comment from you.
And as mentioned: we are currently planning the house and kitchen. Nothing needs to be remodeled, the house has not been built yet.
