ᐅ Door frames with partially tiled walls – Request for example photos
Created on: 5 Oct 2017 12:48
Kaspatoo
In the bathrooms, the wall tiles are only installed up to about 1.50m (5 feet) high. When the door frame is mounted on top of this, a gap appears between the wall tiles and the wall above.
The door installer explained to me that you should leave the tiling area around the frame free first, then install the frame, and afterwards install the tiles.
Advantage: no gap, the frame sits flush against the wall everywhere
Disadvantage: the thickness/depth of the frame is largely absorbed by the thickness of the tiles, which might look odd
The tiler said this is nonsense and that the tiles come first, then the frame is mounted on top, and the resulting gap must either be sealed with silicone or, for a more professional look, covered with an additional wooden strip.
Advantage: the frame is fully visible in its complete profile
Disadvantage: at the top, the frame is much thicker/deeper due to the wooden strip
Of course, each proposed solution is much easier for the person responsible for the installation.
I’m interested in hearing your opinions on the appearance of these approaches.
If possible, could you share photos of how it looks in your case, so I can better understand the differences in appearance? That would be really helpful.
Specifically, I am looking for photos of the following three variations:
1) Frame mounted on the wall and tiles installed up to it
2) Frame mounted on the tiles with the gap sealed by silicone
3) Frame mounted on the tiles with a wooden strip covering the gap
Thank you very much.
11ant5 Oct 2017 15:05
I have (rented, but still like) the version
Kaspatoo schrieb:
1) Frame mounted on the wall and tiled over
in the bathroom (but I misplaced my camera upload cable). In the kitchen, I don’t have this “problem” because the tile backsplash ends well before the door opening. I rarely see option 3), and I don’t have a clear picture of it myself, but I imagine it looks quite nice. For option 2), the frame seems too bulky to me and would cast too much “shadow” above the tiles. Also, with option 2), the tiled area wouldn’t be visually finished with a joint vertically. In my opinion, that looks like a renovation frame and therefore wouldn’t really be suitable for a new build.
Aotearoa
5 Oct 2017 15:46
This is how it is for us:
White door frame on the left, next to it a small square white switch cover on beige tiled wall.
The tiles were installed, and the doors arrived 5 weeks later.
(The gap between the door and the tile still needs to be sealed with silicone.)
Steffen80
5 Oct 2017 15:47
We left out the last row, and the tiler will come back once the door frames are installed.
11ant5 Oct 2017 19:25
Aotearoa schrieb:
The tiles were laid, and the doors arrived 5 weeks later.
That actually fits together very well; both must have worked quite precisely.
So this is probably exactly what the two tradespeople the OP mentioned are worried about—whether they can manage that as well; and that’s why each wants the other to be blamed.
Kaspatoo5 Oct 2017 19:42
Thank you very much for the many submissions so far.
The consensus up to now seems to be that tiling will be done.
Photos of this option (1) have also been provided.
I am now also very interested in seeing photos of options (2) and (3).
Aotearoa
5 Oct 2017 19:51
Actually, the width of the door or the door frame should be fixed. Then it should be possible for any tradesperson to transfer exactly this width to the door opening, plus 0.5 cm (about 0.2 inches) on each side of the frame (I think that’s how it was done for us; I remember a mark next to the door opening).
