ᐅ Does oiling help with squeaky cabinet hinges?
Created on: 18 Nov 2020 08:17
U
Usla36
I have a small issue at home with my Billy shelves from Ikea: the hinges on the doors are increasingly starting to squeak, which is especially annoying when opening them. My question is: Does oiling really help with squeaky Billy hinges, and if so, which type of oil is best suited?
I don’t want to damage the shelf, so I would also appreciate advice on the proper procedure and any possible risks. Are there perhaps alternatives to oil that are effective and safe?
Thanks for your tips!
bente
18 Nov 2020 16:12
I completely understand the issue with squeaking. For years, the hinges on my Billy bookcases have creaked, even though I’ve tried various solutions.
Oiling improved the situation noticeably for me, but I’m a bit cautious about applying too much because I don’t want to risk stains on the wood.
If oiling doesn’t work for someone else, sometimes simply tightening the screws, as mentioned earlier, can help.
If the problem persists, I would appreciate any additional tips on how to eliminate the noise without damaging the doors.
nofomu
19 Nov 2020 07:54
Oiling is the first and most effective step to stop squeaky hinges.
Sewing machine oil or silicone spray work best. Thick greases should be avoided.
Before oiling, quickly check if the screws are still tight; otherwise, it won’t help.
DAMALO
19 Nov 2020 09:17
I know how annoying squeaky doors can be. I had the same problem with a Billy bookcase.
My tip: Take your time when oiling, don't overdo it, and make sure the oil doesn't get on the wood surfaces, or it will leave unsightly stains.
If it feels uncomfortable the first time, let me assure you: it helps, and over time you’ll get the hang of it. 🙂
O
olivernu
19 Nov 2020 10:33
For Billy hinges, I primarily recommend a thin, light oil such as sewing machine oil. It penetrates well into the joints, leaves hardly any residue, and provides long-lasting lubrication.
WD-40 is more of a short-term solution because it contains rust-dissolving agents, so it is less suitable as a permanent fix. Silicone spray is also a good alternative since it does not become sticky or attract dirt.
When applying, be sure to apply the oil precisely to the hinge joints only, avoiding the wood surfaces or visible areas. Careful application saves cleaning effort afterward.
TRA33
20 Nov 2020 08:55
Oiling usually helps; sewing machine oil or silicone spray works well. Don’t forget to check the screws.
