ᐅ Determining the Bathroom Floor Construction – Trial Bore Completed
Created on: 5 Oct 2016 18:30
WerkheimerW
Werkheimer5 Oct 2016 18:30Hello forum,
The bathroom on the first floor in our detached house built in 1990 is going to be renovated. We want to install a walk-in shower with a flush floor as much as possible.
Before starting, we wanted to find out whether this is feasible at all. For this purpose, I conducted a test drill and concluded the following layer structure:
I have the following questions:
Thanks in advance for your opinions and tips!
Werkheimer
- Does the floor structure seem possible or correctly determined? The "nothing" layer is probably polystyrene or something similar.
- In which layer is the drain of the existing raised shower tray likely installed — in the "nothing" layer or the concrete below?
- For a complete bathroom renovation, should the entire floor structure be removed?
- Or should the floor be left as is, only breaking out the area where the future shower will be, and otherwise installing new tiles over the existing tiles?
- Is there anything (obvious) that speaks against installing a flush-level shower?
Werkheimer
Normally, the process should be straightforward.
Werkheimer5 Oct 2016 19:00The old shower is a surface-mounted model, approximately 17cm (7 inches) above the tiled floor.
Werkheimer5 Oct 2016 19:11This is about the preliminary planning for the entire bathroom, which should not only start once the shower has been removed. Therefore, I need actual practical experience regarding typical floor build-ups—and answers to the questions above.
