ᐅ Decision: Double French Patio Door – With Mullion or Without?
Created on: 19 Apr 2015 14:13
abertram
we are currently facing a decision on whether our double-leaf patio door should have a mullion or not. Until recently, I thought it would be better without one. However, our general contractor convinced me to go with a mullion. The main argument was that the door is safer with a mullion.
What are your thoughts on this? And your experiences?
Alex
Alex
In our terraced house, where we still rent, we have a French door (Stulp door). We don’t use it very often, but it’s helpful for moving the patio table outside, bringing in new furniture, taking out bulky waste, etc. Without the French door, these tasks would sometimes be very difficult. The second door opens very quickly and easily with one hand (thanks to 2 hinges). For our new build, we will also have a sliding door.
Bauexperte20 Apr 2015 10:34Hello Alex,
For a standard size of 2.01 x 2.135 meters (6 ft 7 in x 7 ft), a design without a central post is now the norm; therefore, I consider your provider’s concerns unfounded. Only from a window width of about 1.135 meters (3 ft 9 in) per sash, due to the weight of triple glazing, is a mullion a sensible choice—especially if laminated safety glass (LSG) is involved. The warranty period can also be passed by a window of this size without a mullion, but after that...
Edit: Mullion replaced central post.
Edit 2: Mullion:
**This profile attached to the sash divides the window inconspicuously into two or more parts. The mullion profile is part of the window sash and opens together with it. The mullion is not fixed and is therefore also called a loose post.
** borrowed from Veka®
Regards, Bauexperte
abertram schrieb:
Our general contractor convinced me to go with a post. The main argument was that a door with a post is safer.
Edit 2: Mullion:
Regards, Bauexperte
Hello construction expert,
I’m a bit confused right now. A “Stulp” refers to the fixed central post, correct? Are “Stulp windows” windows without this central post? Because one of the window sashes takes over the function of the Stulp, or is that why?
When you say “without Stulp,” does that mean without the central post? Our window is even a bit smaller, 186 cm (73 inches) rough opening dimensions, so about 90 cm (35 inches) per sash. The size shouldn’t be an issue in that case.
Regards,
Alex
Regards,
Alex
Bauexperte20 Apr 2015 11:02Hello Alex,
argh – I fell for it again, sorry; I replaced "Stulp" with "mullion" ops:
Regards, Bauexperte
abertram schrieb:Yes. Among other things, that’s why you need to specify which sash you want to open first when ordering the windows!
Because one window takes over the function of the stulp, or why?
If you write without stulp, that means without mullion, right?
abertram schrieb:Then it’s definitely no problem at all to do without a fixed mullion!
Our window is even a bit smaller, 186cm (73 inches) rough opening dimensions, so about 90cm (35 inches) per sash. The dimensions shouldn’t matter.
Regards, Bauexperte
