ᐅ Combine the BILLY shelving unit with glass shelves or wooden shelves?
Created on: 1 Dec 2020 09:13
Imke8
I am currently deciding whether to combine the standard wooden shelves of my new BILLY bookcase with glass shelves or to stick entirely with wood. The question is whether mixing glass and wood shelves in a BILLY bookcase looks visually inconsistent or if it actually enhances both the functionality and overall appearance. On one hand, I imagine that glass shelves make the unit look lighter and more elegant, but on the other hand, I worry that the different materials within one frame might create a somewhat unsettled look. I am also interested in whether there are any considerations regarding load-bearing capacity or practical use when choosing glass shelves instead of wooden ones. Does anyone have experience with how the combination of glass and wooden shelves in BILLY bookcases performs in everyday use? Are there design or practical aspects I should keep in mind? What recommendations would you give for a stylish and functional setup?
enrique7
1 Dec 2020 11:45
PULAU schrieb:
Glass reflects light, which can be an advantage even in darker rooms
That’s true, but it can also be a disadvantage if the reflections are too strong or appear in the wrong places. Especially with poor lighting design or direct light sources, reflections can be distracting and affect the overall appearance.
Therefore, it’s important to coordinate these effects in advance with the wall colors and light sources. Do you know how the room where the shelf will be placed is illuminated?
Imke8
1 Dec 2020 12:11
enrique7 schrieb:
Do you know how the room where the shelf will be placed is lit?
Good point! The shelf will be in my living room, which gets quite a lot of natural light thanks to large windows, although the shelf itself won’t be positioned directly next to the windows. It will be on a wall opposite the windows, slightly to the side and somewhat in the shade. There are two ceiling spotlights, but they provide rather diffuse, warm white light – no direct focused lighting on the shelf.
So maybe it’s a good environment for glass shelves, as they won’t reflect too much or appear too dark.
I also like the idea of adding some lightness to the shelf with glass – especially with wood, you can often quickly see dust or fingerprints, which bothers me a bit sometimes.
Domau0
1 Dec 2020 13:02
Imke8 schrieb:
Maybe this is a good environment to ensure glass shelves neither reflect too much nor appear too dark
Definitely. Here are a few practical tips for using glass shelves in the Billy unit that you should consider:
1. Glass shelves are easier to clean but can be more easily damaged by strong impacts. So it’s better not to place heavy, sharp-edged objects like large stacks of books directly on the glass.
2. To create a visual connection, you might consider combining the glass shelves with decorative items in wood finishes or warm materials – this creates a harmonious balance between warm wood and cool glass.
3. The position of the glass shelves within the unit can strongly influence the look – installing them in the middle or higher up enhances the feeling of lightness, since glass lets light pass through.
4. Check the load capacity: the specified 15 kg (33 lbs) per glass shelf should be strictly observed, and if you work with many heavy books, it’s better to use wooden shelving or limit glass shelves to purely decorative purposes.
What size is your BILLY unit? The taller or wider it is, the more stability you will likely need.
Imke8
2 Dec 2020 08:54
Thank you for the detailed tips, Domau0.
My BILLY shelf is 80cm (31.5 inches) wide and 202cm (79.5 inches) high. The depth is 28cm (11 inches), which is one of the standard options.
I’m planning to install the bottom three shelves in wood for more stable storage of my non-fiction books. Above that, I will use two glass shelves to keep the top looking light and open.
Domau0 schrieb:
combine the glass shelves with decorative items in wood finishes or warm materials
That sounds really good. For example, I have some wooden boxes and woven baskets that I can place on the glass shelves. This way, the color and materials will stay cohesive.
Do you have any tips on how I can visually loosen up the shelf further without disturbing the “glass/wood combination” theme?
FLONE41
2 Dec 2020 09:45
Imke8 schrieb:
Do you have any tips on how I can visually lighten up the shelf without disrupting the “glass/wood combination” theme?
I find that to be an interesting combination! What has always helped me is to occasionally place plants or fresh flowers between the books and boxes – this adds a natural, lively contrast to the materials and breaks up the surface.
Another idea is to pick a few colors from the book spines and arrange a few carefully selected, tidy decorative items on the glass shelves – not too many, keeping it minimal.
Personally, I also think glass shelves can sometimes feel visually a bit cold, so I like to make the space cozier by adding warm, personal items like nice photos or small wooden figurines.
By the way, I once worried that wood and glass wouldn’t go well together – but in the end, the result was much more harmonious than I expected. Maybe because I deliberately paid attention to mixing the materials. 🙂
elliot
2 Dec 2020 10:18
From a technical perspective:
- The standard BILLY wooden shelves are indeed more load-bearing (30 kg (66 lbs)) than the glass shelves, which usually support a maximum of 15 kg (33 lbs).
- The glass shelves are made from tempered safety glass but are more fragile when handled.
- An asymmetrical layout (combining different materials) can create a modern atmosphere if the materials have a good color harmony and the fittings are professionally installed.
- When combining materials, it is important that all shelf components are correctly installed and level to avoid stress on the glass shelves.
- Maintenance: glass shelves are easier to clean, while wooden shelves often require protective treatments to guard against moisture or scratches.
Conclusion: Combining is feasible if load requirements are observed and placement is carefully considered.
