ᐅ Closed concrete staircase or open steel-and-wood staircase
Created on: 7 May 2019 09:50
Egberto
Egberto
7 May 2019 09:50
Our ground floor is now built, and we need to decide on a staircase. We are choosing between a closed concrete staircase with a central wall poured in place or an open steel and wood staircase. The space beneath the stairs should remain open. There will be another staircase from the first floor to the attic, which will definitely be open. There is also a window in the stairwell on the first floor.
Visually, I tend to prefer the open option downstairs, but I am concerned about noise, especially since the stairwell will be quite tall (about 8m (26 feet)) and the landing at the attic might feel uncomfortably high because of the two open staircases. I understand that an open staircase requires more cleaning. What do you think? Does anyone have specific experience with a similar situation?
Grundriss eines Hauses mit Garage, Wohn-/Essbereich, Küche, Flur, Bad und Terrasse.
Crossy
7 May 2019 13:27
Would you like to remove real names and addresses?
Regarding the question, it’s probably just a matter of personal preference. I would personally always lean towards a concrete staircase (covered with wood).
Egberto
7 May 2019 13:44
The concrete staircase would definitely be covered with wood. My only concern is that it’s not just a matter of personal taste but that it actually has concrete effects,...
Lumpi_LE
7 May 2019 14:01
I think it’s just a matter of personal preference, so I don’t believe anyone can really help you with that.
I have steel with a wooden deck.
Mottenhausen
7 May 2019 15:03
In the floor plan, the staircase is enclosed with storage space underneath.
An open staircase only makes sense if you can see through the "missing" risers, which visually enlarges the room or lets more light in.
Maria16
7 May 2019 16:13
Why do you only have the choice between a closed staircase with a central wall or an open design?
Our concrete staircase has load-bearing walls on the outside and only a fairly open-looking stair railing in the middle.
I personally don’t like a fully built-up central wall, but I also didn’t want open steps because, purely subjectively, I feel they are less safe – as if things could more easily fall or slip through.
