Hello everyone, I have a question that might sound simple but is quite specific for me: Is it possible to convert or modify IKEA Malm beds, which are originally designed as classic bed frames, into something that can actually be used as a sofa?
I don’t mean just temporarily placing a mattress on it, but creating a kind of permanent sofa alternative with a backrest, possibly an adjustable seat area, and reasonably comfortable for sitting.
Has anyone had experience with such a conversion or perhaps technical tips on how to make it stable and functional? I’m interested in the construction, handling of the back parts, and whether it’s even feasible without the bed becoming unstable or losing its aesthetic appeal.
Thank you for your assessments!
I once read that some people convert Malm beds into sofas by attaching angled backrests using metal brackets. The metal brackets provide additional stability and prevent the backrest from wobbling.
It is important to use the correct brackets that are strong enough. Additionally, adding a firm cushion can make the seating area much more comfortable.
If you’re not very skilled with DIY, you could also use ready-made sofa backrest elements as a support, which can then be attached to the bed frame.
Ramon4 schrieb:
I once read that some people have converted MALM beds into sofas by attaching angled backrests using metal brackets.\That's exactly what I meant! It not only looks sturdy but also gives the whole piece a really cool upgrade. Add some homemade cushions – perfect! 🙂
I'd like to try it out right away. You could even add casters under the bed to make it easier to move. Who's in?
Cecilera6624 Jan 2023 09:18If you want to use the MALM bed as a sofa, I recommend thoroughly checking its stability.
The material is designed for lying down, not for weight bearing at backrest height.
Anyone who decides to modify it anyway should definitely add extra reinforcements to prevent wobbling.
For seating comfort, be sure to choose good cushions and an ergonomically suitable backrest.
labar43 schrieb:
I would just give it a try.There is nothing wrong with experimenting if you have good DIY skills. However, the MALM bed should first be checked to ensure that any additional drilling or gluing will not compromise its stability.
Furthermore, the visual appearance is essential. Renovations should either maintain the simple style or be deliberately aimed at a new design.
I recommend always using durable materials to ensure long-lasting use as a sofa.
Thank you for all the detailed answers so far.
I am particularly interested in the aspect of metal brackets and support structures. Is it possible to screw these in without the MALM crossbars breaking or the bed feeling warped afterward?
And what about the padding? Would you recommend ready-made foam cushions, or is it better to make your own?
I also want to keep the overall look appealing—not a messy DIY job, but something that looks and feels durable.
