ᐅ Can Ikea PLATSA furniture be used in environments with high humidity levels?
Created on: 31 Mar 2024 08:23
Mumilis
Mumilis
31 Mar 2024 08:23
I am planning to buy some IKEA Platsa furniture, but I have a question about whether it can be used in areas with relatively high humidity. I live in a region where the humidity regularly exceeds 70%, especially in the summer. Since Platsa furniture is made from coated particleboard, I am interested in how it responds to this level of moisture. Are there any issues with warping, swelling, or even mold growth? Or is this furniture designed to remain stable and durable in more humid environments? I would appreciate any experience reports, technical assessments, or advice on suitable protective measures so I can make an informed decision. Thank you in advance!
Nathanaelk
31 Mar 2024 09:12
Hello Mumilis,
Your question about using IKEA PLATSA furniture in high humidity conditions addresses an important topic, as furniture made from coated particleboard is generally more sensitive to moisture than solid wood.
First, regarding the material: PLATSA consists of veneered or melamine-coated particleboard, which provides a certain protective layer but does not fully prevent moisture penetration. If the humidity level remains above 70%, the particleboard can swell. This happens because moisture enters the material and affects the bonding. The result often appears as swelling at edges, warping, or eventually cracking.
Another factor is room ventilation. Stagnant moist air increases the risk of mold growth on surfaces or in hard-to-reach areas.
A few tips from me:
- Make sure the furniture is not placed directly against exterior walls, which tend to be cooler and damper.
- Ensure sufficient ventilation (regularly airing the room).
- Consider using additional dehumidifiers in the room.
I would be interested to know in which rooms the furniture will be placed and if you have any experience with similar materials under such conditions?
KNUTGI
31 Mar 2024 10:45
Nathanaelk schrieb:
PLATSA is made of veneered or melamine-coated particleboard, which offers some level of protection but does not provide complete resistance to moisture penetration.
This fits quite well with my own experience. I have PLATSA furniture in the bedroom, where the air can get quite humid during winter. So far, the furniture has held up without issues, but I make sure there is always some air circulation and that no wet laundry piles are placed under or next to it.
I would say the key is definitely regular ventilation, not placing the furniture directly in bathrooms or basements, and of course avoiding storing soaked items on the furniture.
With a bit of care, the furniture can actually work well even in somewhat damp apartments. Well, of course that’s no guarantee, but they are certainly not unsuitable for those conditions. Sometimes practical handling is more important than just the technical specifications, ;-).
Blavin
1 Apr 2024 07:59
The basic material properties of PLATSA furniture are crucial when it comes to moisture resistance.
It consists of particleboard panels with a melamine coating. This coating is water-repellent but not waterproof. Prolonged exposure to high humidity can cause water to penetrate the edges of the material, as these are usually not sealed. The result can be swelling, warping, and in the worst case, mold growth in the affected areas.
Locations in rooms with high humidity—such as bathrooms or poorly ventilated basements—are therefore not recommended. For damp rooms, other materials like solid wood with special sealing or metal furniture are much better suited.
When using furniture in moist environments, it is also important to regularly check for any visible damage. Good air circulation is, in my view, essential.
Summary:
- PLATSA is moderately moisture-resistant
- High humidity environments can cause damage
- Suitable placement and ventilation are crucial
- Alternative furniture types are preferable in areas with strong moisture
nojaus
2 Apr 2024 12:17
Mumilis schrieb:
Are there problems with warping, swelling, or even mold formation? Or are these furniture pieces designed to remain stable and durable even in more humid environments?
I completely understand how important this information is, especially when living in an area with high humidity. I had a similar experience when I set up my PLATSA cabinets in an older apartment that sometimes had high humidity levels.
After about a year and a half, the furniture shows no significant damage; however, I was careful to regularly ventilate the rooms and keep the furniture away from windows and cold exterior walls.
This caution likely helped me avoid mold growth and swelling.
Besides the construction, your daily routine is also important because furniture only lasts as long as we properly care for and protect it.
My recommendation: If you’re unsure, check when buying whether the surface is well sealed, and consider whether the location is extremely humid or only moderately so. That way, you can better adjust your approach.
