I am currently considering using Ikea PLATSA as a base for DIY living room furniture. Since PLATSA is originally designed as a modular cabinet/storage system, I wonder if it is suitable for making custom living room furniture.
Specifically, I am interested in whether the system is stable enough in terms of materials and design to be used as TV units, lowboards, or shelving. I am also curious about how flexible the modules are when building non-standard sizes or different constructions compared to the standard combinations.
Does anyone have experience with PLATSA in these kinds of non-standard living room solutions? Are there practical tips or pitfalls to be aware of?
Thanks for your input!
PLATSA is generally stable enough to support light to medium loads, so TV units are feasible. Be cautious with very heavy televisions, as the weight is borne by the shelves.
Adjustments to the dimensions can only be made within the given range, as the system is not flexible enough for highly customized sizes or shapes.
When using the Ikea PLATSA as a DIY system for living room furniture, the connection technique is particularly important. The modules can generally be connected and arranged well, but you should keep an eye on the load-bearing capacity of the back panels and shelves.
For a TV cabinet, for example, I recommend reinforcing the shelves or using sturdy substructures. The pre-drilled holes and mounting options are somewhat limited, which restricts flexibility with unusual dimensions.
On the other hand, the system is visually appealing and allows for individual customization through the various doors and surfaces.
Hey,
I think PLATSA is a real winner when it comes to getting creative! 👏 Sure, it’s not the heaviest furniture out there, but especially for living room pieces that don’t need to be extremely heavy, it’s great. You can easily stack and combine the modules to create cool lowboards or shelves.
However, I wouldn’t recommend sitting or jumping on it – better to use it more gently. Adapting it to sloped walls can be tricky since the system is quite linear. But with a bit of DIY creativity and maybe some sandpaper, it can definitely work! 😉
So why not give it a try? PLATSA deserves to be celebrated for creativity!
Demetrius24 Jan 2020 09:39ritotar schrieb:
You can easily stack and combine the modules to create cool lowboards or shelving units.I can only confirm that. Some time ago, I built a small TV stand using PLATSA. The assembly was enjoyable because it offered quite a bit of flexibility, and it looked stylish.
However, I also had concerns about stability. Especially when combining four or more modules, I would recommend securing them additionally to the wall. This provides safety, particularly if there are children in the house.
What helped me was reinforcing the back panels with small brackets, which improved stability. I’d be interested to hear if others here have had similar experiences with the stability limits?
