ᐅ Can I equip IKEA BESTA furniture with glass or acrylic fronts?
Created on: 29 May 2022 18:37
tayolu
tayolu
29 May 2022 18:37
I am currently planning to upgrade my existing IKEA BESTÅ furniture and am wondering if it is practical and worthwhile to replace the original fronts with glass or acrylic fronts. Specifically, I am interested in whether these materials are compatible with the BESTÅ system in terms of installation, stability, and durability.
If anyone has experience with this or knows if IKEA itself offers suitable glass or acrylic options, I would also be interested in information about the differences between glass and acrylic fronts regarding scratch resistance and maintenance.
It would also be helpful to know if there are recommended third-party suppliers who provide such fronts in the correct dimensions, or if it is better to have them custom-made.
Thanks in advance for your opinions and tips!
dijan
29 May 2022 19:12
Hey tayolu!
Regarding your question about whether you can equip IKEA BESTÅ furniture with glass or acrylic fronts: basically, yes, the system is quite flexible. IKEA even offers glass fronts specifically for BESTÅ in some cases, usually clear glass doors or those with frames.
As for installation, you’ll need some DIY skills: glass fronts are significantly heavier and often require special fittings. Acrylic is lighter but less scratch-resistant and can yellow faster when exposed to sunlight.
About third-party suppliers: there are several companies that custom-make doors and fronts for the BESTÅ system, including glass or acrylic options. Be aware, though, that prices can escalate quickly.
My advice: if you want an elegant and durable solution and don’t mind a bit of effort, go for genuine glass fronts from IKEA or a specialized supplier. For quick projects or budget options, acrylic fronts can be an alternative, offering some flexibility and lightness.
Hope this helps! 😊
Siflo
30 May 2022 08:46
Additional information:
- IKEA offers modular fronts for BESTÅ, including framed glass variants, but no pure acrylic fronts.
- Glass fronts are usually securely fastened and provide high stability; however, their weight significantly increases, which puts more strain on the hinges.
- Acrylic is lighter and more impact-resistant than glass but is more prone to scratching and may yellow over time, especially when exposed to direct sunlight.
- Third-party suppliers provide custom-made fronts in glass or acrylic, but compatibility with IKEA fittings should be checked in advance.
- Installation often requires adjustment of the mounting points.
Conclusion: Glass fronts from IKEA or specialized manufacturers are the safer and more durable choice. Acrylic can be a lighter, more affordable alternative but requires more care and caution in use. The intended usage and room climate should also be considered when making a decision.
BLAKEO
31 May 2022 10:23
Siflo schrieb:
IKEA sells modular fronts for BESTÅ, including framed glass options, but no pure acrylic fronts.
This brings me to an important question: How practical is it to rely on third-party suppliers when IKEA already offers its own glass fronts? I doubt that external providers can guarantee the same level of precise fit and material quality. This can quickly lead to installation difficulties and long-term issues like poor adhesive bonding or warping.
dijan schrieb:
Acrylic is lighter but less scratch-resistant and can yellow more quickly when exposed to sunlight.
That is exactly the crux of the matter for me. Although acrylic is cheaper and lighter, the question remains whether it is durable enough for everyday use. Perhaps such “custom-made” options only make sense in exceptional cases or for purely decorative purposes.
Additionally, I would be interested to know if anyone here has experience with the feel and appearance of acrylic compared to glass. Acrylic can certainly be visually appealing, but long-term use and maintenance might lead to disappointment.
Finally, I would also highlight the safety aspect: glass, especially safety glass, clearly offers advantages in resistance to scratches and cleaning agents. Acrylic can be damaged more easily if not handled properly.
